ABS/Active Handling/Traction Control problem
Old Sep 20, 2008 | 01:16 PM
scubadiver4u's Avatar
scubadiver4u
6th Gear
Default ABS/Active Handling/Traction Control problem
I recently had two computer modules replaced in the ABS. About a month later the display indicated that the ABS, active handling and traction control need to be serviced. When I took it in, the repair shop could not find anything wrong. The shop thought it was probably just a glitch. They reset the car and the problem went away for about a month, but now the display is telling me that I need to service it again. I haven't noticed any difference with the handling of the car since the computer modules were replaced. Has anyone else had this problem?
Old Sep 20, 2008 | 02:58 PM
Bill Dearborn's Avatar
Bill Dearborn
Run the codes and post them here. To run codes turn on ignition and push and hold the options button, then while holding the options button push the fuel button 4 times. This will start the On Board Diagnostic system. The codes will displayed on the DIC one subsystem at a time starting with the Powertrain subsystem followed by the ABS subsystem, etc.
Bill
Old Aug 5, 2018 | 08:38 PM
Drjimz's Avatar
Drjimz
1st Gear
Drjimz 2000C5 with 61000 mi DIC indicates traction control and active handling inop multiple codes through the years but most notable was 28 TCS C1295 HC What does this code refrence? Thanks in advance.
Old Aug 6, 2018 | 12:11 AM
BigGun's Avatar
BigGun
You are posting to a 10 year old thread. Start a new one of your own and post the codes you have now. The C1295 indicates a brake light problem. If you get this code it will disable traction control and active handling.
To ABS/Active Handling/Traction Control problem
