Car wont start...getting no spark
Here is what I know.
1. I have no spark at the spark plugs based on attaching a timing light.
2. I have fuel pressure.
3. The engine cranks over but does not start
4. When I turn the ignition on, I get this message "Reduced Engine Power"
Here are the codes I just pulled.
TCS - C1278 H
BCM - B2527 H
SDM - U1040 H
LDCM - B2264 H
I cleared those codes and tried to start the car, but still had no luck.
Anyone have a clue what could be the culprit?
TCS - C1278 H
BCM - B2527 H
SDM - U1040 H
LDCM - B2264 H
Minifuse(s): 17,18,19,22,24. (check condition of fuses as well)
All these fuses are supplied by the ignition relay. If there is no voltage to the fuses, check the condition of minifuse 16.
17 - 11.8
18 - 4.7
19 - 11.9
22 - 4.6
24 - 11.8
Note - There was no fuse in the #17 slot.
All fuses including #16 were all good.
Should I?
I'm working in Korea this week, and just got to work, so I can't stay online. If you PM me your email, I'll send you the service manual procedure.
On the other hand,,,if you atach one meter lead to ground and read the metal contacts on top of the fuse, you should see the same voltage on both contacts. If you see 12 VDC on one side, and zero on the other,,,the fuae is BAD!
Hope this explains it so you can troubleshoot.
Bill C
Bill C
