Gasket Maker on rocker threads?
Old Sep 23, 2008 | 03:08 PM
95BlueBomber's Avatar
95BlueBomber
Default Gasket Maker on rocker threads?
Does anyone else do this? I was just looking at my heads and noticed the port job opened them up where when the rockers are off you can see straight into the intake port. Do you think there is enough vacuum there to pull oil through?
Old Sep 23, 2008 | 03:23 PM
vettenuts's Avatar
vettenuts
Definitely will. Blue loctite or a thread sealer.
Old Sep 23, 2008 | 06:03 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
permatex thread sealer
Old Sep 23, 2008 | 06:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes, you will burn a lot of oil if you don't use a thread sealant on the rocker bolts.
Old Sep 23, 2008 | 06:24 PM
vettenuts's Avatar
vettenuts
Hylomar is an outstanding product for this application as well.
Old Sep 23, 2008 | 07:52 PM
Patches's Avatar
Patches
I noticed oil seeping into the runner after doing heads/cam. When I put in Harland rr's shortly after that, I used sealant on the rocker bolts and the runners stayed clean after that.
Old Sep 23, 2008 | 08:27 PM
ArKay99's Avatar
ArKay99
+6. I use Permatex red or black. The sensor safe stuff.
To Gasket Maker on rocker threads?
