FAST 92MM is it worth it?
Old Sep 25, 2008 | 05:56 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
nitro dave's plate kit.
Old Sep 25, 2008 | 06:57 PM
2001blkvet's Avatar
2001blkvet
and why do you say nitrous daves plate kit
Old Sep 25, 2008 | 07:06 PM
Scubanme's Avatar
Scubanme
Originally Posted by 2001blkvet
i want the extra hp for all the time use, i know i can use more nos but that is going to just be an ins policy if i need it. i want everyday hp as well
Thats why you go F/I, power all the time and no bottles to refill. Yep it will happen to be empty when that big race just happens to appear when least expected. If you go Nitrous, get a bottle remote bottle opener.
Old Sep 27, 2008 | 01:04 PM
ctusser's Avatar
ctusser
I had a fully ported LS6 intake and TB and was making 423whp on my mild cam/ported 243 heads Z06. I then switched to a fully ported Fast 90 and ported LS2 TB, against LPE's advice (they told me I wouldn't gain much and they were right.) I only gained 5 peak HP and lost a couple HP everywhere below peak and a retune didn't help. A lot of money wasted IMO. It would have made more of a difference if I had a big cam. But porting your LS6 intake and TB is worth it from a cost perspective.
Old Sep 27, 2008 | 08:54 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by Kurtomac
...i say if you plan on doing the nitrous just save the cash and throw a extra 20hp worth of nitrous on it
not a FAST **** or anything...n
save cash?? um ok, after a spending 1300 dollars on bottle refills, your still down 20HP when the bottle is empty Vs. having it for life with a simple bolt on. you do not make any sense.
Old Sep 27, 2008 | 09:03 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Originally Posted by Tony Mamo @ AFR
I believe Ike picked up 22 RWHP if I recall (in addition to the solid torque gains)
Actually 24RWHP with your FAST version but whos counting?
Old Sep 27, 2008 | 09:14 PM
Joy of 6's Avatar
Joy of 6
I have a similar set up. If you go for the ported intake then you really need to upgrade the TB too. I did get the ported 90 mm intake and the LS2 ported TB. Put it on the dyno and lost about 25 hp. We decided that there was something wrong with the dyno and he will have it calibrated. (All the important parameters were right on the money) However, there is a real difference. I track at Portland most of the time and gained about 10mph on both the front and back straights. so there was a SOTP gain
Old Sep 27, 2008 | 09:25 PM
ctusser's Avatar
ctusser
I guess that's why common sense isn't science. Logically that doesn't seem to pan out. I went to the same dyno you were at, it was one of the motivators for me to sell my car to save me from myself
Old Sep 27, 2008 | 09:48 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
I have heard others say this EXACT same thing plus I saw a comparison from a magazine that compared the FAST, LS1, LS6, BBK, and a couple of other intakes. Believe it or not the winners:
1. The FAST and the LS6 were just about tied for the number 1 spot.
In the article they said if cost was a factor and your car was pretty stock with just bolts ons such as an exhaust or even a CAM, that the best way to go was to port your LS6 intake or get one and port it. It will provide you a few extra HP or even more if your upgrading from the LS1 intake. Cost is nothing if you have the LS6 intake already. If your upgrading from the LS1, its around $500 plus the porting. About half what the FAST costs. HP to HP, the LS6 intake was only a couple of HP lower then the FAST. Plus the FAST's extra HP was way up top at the high RPM, a place where you really couldn't feel it, especially on a street driven car.
The conclusion was that unless your spending $$$$$$ and creating a whole engine package (such as a rebuild) that is going to really utilize the FAST and be built to compliment it, your better off just sticking with the LS6 and porting it.
Old Sep 27, 2008 | 10:26 PM
OO7's Avatar
OO7
hay,is that 1300 just for the intake or that includes custom porting,i can get you a 92mm for 899 and a custom billet 90mm TB for 450
i am also direct with TNT(TEXAS NITROUS TECHNOLOGY)
i have a brand new stage I kit for 599
Old Sep 27, 2008 | 10:31 PM
OO7's Avatar
OO7
also the TNT kit is one of the best on the market for C5's & 6's
on the 100 shot setting you will get 106rwhp
Old Sep 28, 2008 | 10:34 AM
legman's Avatar
legman
I have a 2000 LS1 and I am upgrading to PRC Stage 1 243's from 853's, Whiplash cam kit, and am considering Fast 92 with matching ported 92 TB from Texas Speed....for the intentions of my car, I think my choices should work well together even with a conservative tune.....
The comparisons of the intakes, wonder if they ported or "out of the box"? and is the FAST already ported when new?......
I might have went with the LS6 combo had I started out with the LS6 as a base....
Old Sep 28, 2008 | 11:55 AM
  #33
ctusser's Avatar
ctusser
That should be a good setup, I'm guessing 440+ whp. The Fast is pretty good out of the box but doesn't come ported. For my setup a Ported LS6 was better than the Ported FAST but you're going to make more power higher in the RPM with that cam so the FAST will probably be better for your application.
