PCM Wiring info needed please...
Old Sep 26, 2008 | 09:20 AM
ROJO99's Avatar
ROJO99
Default PCM Wiring info needed please...
I have issues with my PCM, ended up with a replacement unit and I am trying to trouble shoot a possible error. Antways can comeone tell me what if any voltage should be read accross the Star connector at the BCM? Last night with the old PCM in I checked the Star connector and the TAN wire that is from the PCM (I believe this is the DATA LINK wire) was ready a voltage that pulsed from .42-.25 volts. Is this acceptable?
Thank you in advance here from wiring Hell...
Old Sep 26, 2008 | 01:43 PM
NavyDoc2007's Avatar
NavyDoc2007
Not sure if this will help but here you go. I've been reading up on the serial data bus and those star connectors myself after having an issue last night...
http://forums.corvetteforum.com/show...ght=bus+serial
