electrical problem
Old Sep 30, 2008 | 09:14 PM
twobit's Avatar
twobit
Default electrical problem
i got in my 2003 z and and tried to start it.it went click and then the dash and all instruments started to fade it and out.also clicking comming from passenger side.i found a kick plate and mabe the computer.no problems up till now.help please
Old Sep 30, 2008 | 09:20 PM
lucky131969's Avatar
lucky131969
I would suggest the normal stuff...checking the battery cables for security and corrosion. In all fairness, the battery is 6 years old...so it's probably just time.
Also, what are you referring to with regards to a "kick plate and maybe the computer"?
Old Sep 30, 2008 | 09:38 PM
twobit's Avatar
twobit
at the bottom fo the passenger floor board a carpeted plate comes out and it looks like the computer
Old Sep 30, 2008 | 09:54 PM
lucky131969
ok. Your PCM is not accessible from inside the car.
Old Sep 30, 2008 | 11:06 PM
bestvettever's Avatar
bestvettever
Default Electrical Problem
Hi, of course check the cables for tightness and cleanliness at the battery, ground, starter lug, and underhood fuse box. But it sounds as though your battery is done, that would be my first best guess. Take it and have it load tested at Pep Boys, Advance, or Autozone, they don't charge usually.
Then get a new AC Delco and drive on.
Good Luck
Old Sep 30, 2008 | 11:26 PM
mellowyellow01vert's Avatar
mellowyellow01vert
I have found that a weak battery will cause a bunch of problems, most of them, here today and gone tomorrow, then back to embarass you at the car show. Get the battery checked first. If it checks OK, then start looking for corrosion, especially around the ground lugs.
Good Luck.
Old Oct 1, 2008 | 02:06 AM
DeeGee's Avatar
DeeGee
Some good advice here but those are classic dead battery symptoms
A battery change and you'll be good to go.
Old Oct 1, 2008 | 08:31 AM
twobit's Avatar
twobit
thank you to all. I will check that tonight. what was the thing under the kick board on the passenger side floor up near the fire wall?
Old Oct 1, 2008 | 03:39 PM
Crazy_Steve-O's Avatar
Crazy_Steve-O
I have a 2003 Z as well. Your symptoms, as others have already mentioned, are really pointing towards the battery. Mine did similar stuff about 5 months ago. I jumped it off my wife's car to get it running, went straight to the store and replaced the battery. If the battery doesn't fix it, it's probably a loose ground somewhere.
Old Oct 1, 2008 | 03:49 PM
DeeGee's Avatar
DeeGee
What you're hearing is chattering relays in the fuse box with the low voltage from the dead battery
Old Oct 1, 2008 | 07:37 PM
twobit's Avatar
twobit
checked the battery 12.36 volts with terminals off. 6 volts with terminals on. yes yes yes
thank you thank you all.
twobit
Old Oct 2, 2008 | 01:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You've got 12.3 volts with no cables attached but when you connect the cables, it drops to 6 volts??? Either a seriously dead battery or you've got something dragging it down badly. First thought is the battery of course.
Old Oct 3, 2008 | 02:10 PM
Crazy_Steve-O
twobit
You have that backwards? Replace the battery, but if a similar symptom exists with a new battery, then you definitely have a grounding problem somewhere. Actually could be a loose hot lead somewhere that is shorting out.
Get that battery swapped and give us an update. Good luck.
Steve
2003 EB Z06
To electrical problem
