Traction Control Problems, HELP!
Old Oct 10, 2008 | 01:13 AM
C5Natie's Avatar
C5Natie
Default Traction Control Problems, HELP!
When I drag race i turn off my tc in order to do a burnout but lately it wont disengage. The off light will be on but the car bogs down in the water box. I then shut the car off then on really quick and hit the tc off button really quick. Then the car will do a burnout with no problems. Is my tc taking a dump? Is "competition driving" mode better? Will comp mode let me do a burnout? Car is a 2002 coupe. You can see my mods in the profile. Its embarassing and a hassle when Im racing. Any help or suggestions will be greatly appreciated, thnx.
Old Oct 10, 2008 | 01:24 AM
Bill Dearborn's Avatar
Bill Dearborn
Comp mode will let you do a burn out. Have you used the On Board Diagnostics to check for codes?
Bill
Old Oct 10, 2008 | 02:06 AM
C5Natie's Avatar
C5Natie
Bill
Yeah, everything looks ok. Its odd. Guess I'll be using comp mode from now on.
Anyone have a clue whats wrong?
Old Oct 10, 2008 | 08:09 AM
trussme's Avatar
trussme
Default T/c...
The push button on a (2002) console is supposed to turn off/on both the Active Handling and Traction Control assists ( retaining the abs feature). It appears yours is not deactivating T/C, until you hold the push button down until "Comp" mode displays...In the Comp mode you still retain the A/H assist feature.
Old Oct 10, 2008 | 08:58 AM
C5Natie's Avatar
C5Natie
Any idea why the tc aint working? Anyone else have this problem?
Old Oct 10, 2008 | 11:27 AM
trussme's Avatar
trussme
maybe your EBTCM has a flaw in it?...and no, mine works just like the Owners Manual says it should.
To Traction Control Problems, HELP!
