Steering Column Drippage....
Old Oct 12, 2008 | 10:34 PM
mrC5er's Avatar
mrC5er
Default Steering Column Drippage....
Noticed this fluid seeping out at the bottom end of my steering column....can anyone tell me what it is, and what might be causing it?
(Picture was taken looking at the bottom side of the end of the columnn where it passes through the firewall. Oil/fluid is running down the cover towards the carpet.)
Thanks in advance,
Mike
Old Oct 12, 2008 | 11:21 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
possibly grease from something electrical that is getting too hot. Shouldn't be anything else there.
Old Oct 13, 2008 | 02:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a seal on the fire wall that the steering shaft goes through. That could be water that leaked through that seal. Squirt a water hose on the seal and see if water comes through.
BC
Old Oct 13, 2008 | 07:45 AM
LoneStarFRC's Avatar
LoneStarFRC
Check your brake master cylinder in case it's brake fluid working it's way over there and running down. Might even try unbolting it from the booster and pulling it forward slightly to see if it's wet behind the mounting flange.
HTH
BTW, wouldn't hurt to check your clutch M/C too.
Old Oct 14, 2008 | 12:33 AM
mrC5er's Avatar
mrC5er
BC
HTH
Thanks for the input guys.....
I don't see any signs of leakage from the outside in through the column seal, and after consulting the service manual, I'm leaning towards it being some type of lubricant that's possibly coming from the telescopic column actuator. The actuator is mounted directly above the column, and if anything is seeping from it, it would fall onto the column and eventually find its way to the location seen in the picture. I'll keep an eye on it for a while.
In the meantime, could some of you take a look at the same area on your car, and see if you're seeing the same seepage?
Again, thanks for the help.
Mike
Old Oct 14, 2008 | 10:29 AM
LoneStarFRC
Mike
Try giving this "fluid" the smell test.
Old Oct 14, 2008 | 07:44 PM
mrC5er's Avatar
mrC5er
I did.....no appreciable odor...(fragrance?)
Old Oct 14, 2008 | 08:04 PM
LoneStarFRC
Both brake and clutch fluid have that certain alcohol aromatic type smell that's very unique and tends to dry fairly quickly.
If you're pretty certain it's not brake/clutch fluid, I would next suspect water.
Does it wipe off cleanly with just a water dampened cloth or does it take some kind of cleaning product to remove the stain? Is it sticky?
To the best of my knowledge, there is no component involving the steering column that uses a lubricant with that thin a viscosity, that would allow it to "run". Any lubricants in the column assembly would likely be using a grease of some type such as lithium or something similar and if they were ever being heated to the "running" point, you would have a lot more serious problem from just the heat alone, never mind any leakage.
Also, don't assume that where you're looking is the source of the problem. If you happen to have excess water in your HVAC duct work it may be coming from the duct work. Where you're seeing it just may be where it happened to become visible. You might even try pouring water all around the base of your windshield and into the plenum area too to see if it shows up inside.
HTH
Old Oct 14, 2008 | 09:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To Steering Column Drippage....
