Balancer bolt (specifics)
Old Oct 19, 2008 | 07:07 PM
T.J.'s Avatar
T.J.
Default Balancer bolt (specifics)
I went to the local bolt shop and they have some of the needed parts, but the clerk said that he needed to know the specifics of this pic.
I've found an id for:
M16-2 threaded rod 300mm (length??)
M16-2 nuts (4)
M16 fender washer (He questioned why fender washers. Diameter
is to small for the rod.)
Black clamp(?)
He had washers that were the right diameter, but not very wide.
Old Oct 19, 2008 | 10:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
M16-2 nuts (4)
Black clamp(?)
Are you trying to make a damper installation tool??? If you are,,,just hack the head off the old crank damper bolt and have that metric piece welded on to some standard all thread. That way you dont need to spend all that money and time on metric crap. It will cost you half as much and half the time.
Thats what I did and it worked fantastic!!
If your looking for a replacement damper bolt, you either have the choice of GM part or ARP part. I choice ARP and Im very glad that I did.
Bill
Old Oct 20, 2008 | 10:21 AM
LDB C5's Avatar
LDB C5
McMaster Carr has everything you need on line, including the fender washers. It cost me less that $30.00 including tax & shipping.
Old Oct 20, 2008 | 10:23 AM
vsocks1's Avatar
vsocks1
There is a guy over on LS1tech that sells a really nice tool for $44 shipped! Not worth making one in my opinion..
Old Oct 20, 2008 | 10:51 AM
LDB C5's Avatar
LDB C5
3 nuts; a hand full of fender washers and a piece of threaded rod is not much work to put together
Old Oct 20, 2008 | 10:55 AM
vsocks1's Avatar
vsocks1
Maybe not but is it really worth the effort?
Look at this tool:
http://ls1tech.com/forums/showthread.php?t=391883
Just another option...
To Balancer bolt (specifics)
