Its wire B13 It would be the BLACK wire. It grounds at Splice Pack SP-208. That grounds at Chassis Ground G-104 which is on the frame next to the battery.
BC
could you point that out on the back of the insturment cluster?
Pin Wire Color Circuit No. Function A1 -- -- Not Used A2 LT GRN 11 Headlamp High Beam Supply Voltage A3 WHT 103 Headlamp Switch Headlamps On Signal A4 BLK/WHT 99 Windshield Washer Fluid Level Signal A5 -- -- Not Used A6 TAN/WHT 33 Brake Warning Indicator Control A7 DK GRN/WHT 817 Vehicle Speed Signal A8 BLK 150 Ground A9 -- -- Not Used A10 DK GRN/WHT 357 Oil Temperature Sensor Signal A11 GRY 1036 IPC Class 2 Serial Data A12 -- -- Not Used A13 PNK 139 Ignition 1 Voltage A14 ORN 1640 Battery Positive Voltage A15 LT BLU 14 Left Turn Signal Status Signal A16 DK BLU 15 Right Turn Signal Status Signal A17 WHT 121 Engine Speed Signal B1 -- -- Not Used B2 BLK/WHT 238 Seat Belt Switch Signal -- Driver B3 -- -- Not Used B4 PPL 333 Brake Fluid Level Sensor Signal B5 WHT 717 Illuminated Display Signal B6 GRY/BLK 1458 Instrument Panel Lamp Supply Voltage - 4 B7 -- -- Not Used B8 BLK 470 Low Reference B9-B10 -- -- Not Used B11 WHT 375 Skip Shift Indicator Control B12 -- -- Not Used B13 BLK/WHT 851 Ground B14 -- -- Not Used B15 BLK 150 Ground B16 BRN/WHT 419 MIL Control B17 BRN 9 Park Lamp Supply Voltage
What are you up to now Radio Flyer? You've got one of the most active imaginations on this forum and I always look forward to your projects!
this wasn't so much a project as a repair. Frank of Frank's Vettes is the mechanic that does most of the work i don't have the experience, tools or time to do. He's been having trouble with a few instument cluseters that are drawing a significant amount of amperage causing the battery to drain. I tested all the circuits for resistance and believe the problem to be the "seatbelt-off" bulb in circuit #B2 . I'm hoping that's the problem because it's causing the readings on ALL the circuits to have 203 M-ohm more resistance than usual.
I took the panel apart and found there was no bulb at all in the socket. I'm thinking that putting a fresh bulb in there should solve the problem.... as long as the guy wears his seat belt
Not sure I understand your logic. According to Ohm's Law (Voltage=Current x Resistance) higher resistance reduces current.
I'd think that the last thing that you'd have is power drain with all of the power saving led's that are in your car!
I was hoping that it was a Cool project, but I hope that fixes it for you!
Bill
I'm not exactly sure what's wrong or why. All i know is there was a bulb missing on the circuit that wasn't the same as the IPC that was good. Maybe it needs to re-set itself. if it works yay, if not, he now has a bulb that was missing.
The IPS wan't from my car. it was from one of Frank's Customers. I'm considering swapping out my IPC bulbs for LEDs pending what Tstar has to say about his experience.
