I read about how doing the anti venom "add washer" trick works to improve shifter performance and lets it feel less notchy. More smoother.
I have a stock, but shortened shifter, and was thinking of doing this mod. Is there anything to be worried about when doing this? I read that the brass washer goes between a bolt and the tranny. I am weary about doing something that may have any repercussions on my transmission.
Just looking for a little information.
Also anyone have a part number for the washer that can be used? I read it as "brass washer". Does it have to be brass?
My brother and I have done the mod to our vettes without any problems.
The washer does not have to be brass. The washer is about the size of the oil pan bolt. I think if you search for some of the older threads someone says what size washer to use.
I would test it with 1 washer first and see how that works. If you still want a little less resistance add another washer.
Probably want to use a little silicone sealer to small gasket type material to make sure there is no small leak.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Try It....You'll Like It
Originally Posted by XtremeVette
Ok found the link. I guess the 1/8 thickness is pretty important to come close to, to feel a difference.
I've done this little mod to my car and three of my friends. Three of us feel a big difference and the other guy doesn't.....maybe I didn't space his out with enough washers.
I can't see why you would do this with a stock shifter, even if it is shortened. It is a great mod for those who have a Hurst, BPP, or Ripper, since the shift effort using any of those is significantly higher than it is with even a shortened stock shifter. I used two .050-inch thick copper (or brass) washers and my BPP is much easier to pull out of or push into gear.Side-to-side effort is still a bit higher than I'd like when going into 5th from 4th, however.
well from what I read through the pretty lengthy post that described it to the T, the shifter really has nothing to do with it. You are essentially moving the ball at the end of the plug further away from the detent rails which it turn makes the shifter easier to ride up over the "hills" or bumps that you feel when passing the neutral position. You will and should feel a difference with any type of shifter installed. The shorter throws seem to show it more because by nature those shifters are harder to get into gear, but the stockers will also show noticeable improvement over the "notchiness". Hmmm interesting I did notice you mentioned that you too even with the short throw have difficulty going from 4th to 5th. I have this too, I figured for me its just cause I haven't driven a standard for very long but it is rather weird, I can bang all the other gears pretty easily but for some reason 4th to 5th just doesn't feel natural. Its like you have to put that extra little effort to kind of pop it up there or something.
I just noticed the thread I was referring to above that I got my information from, you were in on this thread lol. (mneblett) definitely seems to know what he is talking about
