Long Block vs Short Block?
Old Oct 28, 2008 | 04:16 PM
Choreo's Avatar
Choreo
Originally Posted by AU N EGL
looks like re manufactured
http://www.sdpc2000.com/product/8901...tiacFYLS1.aspx
Dont worry about it, it is good as new. Look how many times many guys rebuild their engines.
I called Scoggin-Dickey and they said that the one they sent was NEW. Apparently they have the option of selling new or remanufactured under that description?
Old Oct 28, 2008 | 05:01 PM
AU N EGL's Avatar
AU N EGL
New? That means it is an LS6 block, Very Cool
Old Oct 28, 2008 | 05:57 PM
N4cer's Avatar
N4cer
Actually it's hardly any difference between the LS1 and LS6 blocks. Not really "cool" since although there is theoretical (never yet shown in performance) improvement in bay to bay breathing, it also means less structural integrity. It's a trade off at best. Not good, but not bad. It just IS.
Old Oct 28, 2008 | 08:14 PM
Choreo's Avatar
Choreo
Hey, let me bask in the delusion that I am getting an "upgrade"!
Old Oct 28, 2008 | 08:56 PM
N4cer's Avatar
N4cer
LOL sorry.
Old Oct 29, 2008 | 07:21 AM
AU N EGL's Avatar
AU N EGL
actully there is. Drag race engine builders say there isn't Road race engine builders know there is
LS6 Blocks have far better coolant and oiling gallies. a Bit more aluminum around the back side of the block, #7 & #8
What this means, is the #7 and #8 cylinders do not fail as in the LS1 blocks have or can. When an LS1 fails under high strees, it is most likely poor oiling around #7 or poor cooling around #8
However, unless your running 3000 + RPMS 20 to 60 mins at a time several times a weekend, and no street driving, ( road racing) it does not matter.
More HP is not likely.
That is why the LS6 block was developed over the LS1 block.
Old Oct 29, 2008 | 08:43 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Might find the following link helpful.
http://www.corvetteactioncenter.com/...06/ls1ls6.html
Old Oct 29, 2008 | 10:32 AM
N4cer's Avatar
N4cer
Everyone has a theory. Especially those with an LS6 block. I actually believe (through research) the intake to be the cause of the #7 cylinder going bad. Oh and that's what most of the world accepts as the reason as well.
Old Nov 7, 2008 | 08:08 PM
Choreo's Avatar
Choreo
So... here are some pics (finally) of the new replacement engine. Can you tell if this is and LS1 or LS6 from these photos?
Old Nov 7, 2008 | 09:01 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Did the cylinders say 241 or 243 on the corners? You got a pic of every number but that one.
Block serial number is for a LS6 block
Old Nov 8, 2008 | 12:54 AM
Choreo's Avatar
Choreo
I guess that is good news? I am assuming this is the "241" you were referring to...
Does this mean it is an LS6 Block with LS1 Heads?
Old Nov 8, 2008 | 07:00 AM
AU N EGL's Avatar
AU N EGL
241s are LS1 heads, but it is a LS6 Block
Ohh Engine ****
Old Nov 8, 2008 | 02:56 PM
  #33
Choreo's Avatar
Choreo
Ohh Engine ****
Great!
Were there any improvements/changes in LS1 heads between 2001 - 2004?
Old Nov 8, 2008 | 04:41 PM
  #34
AU N EGL's Avatar
AU N EGL
Great!
Dont think so. Being new heads would have new springs and valves.
Think you in very good shape.
Trust the rest of the build up will go smooth
Congtrats again
Old Nov 8, 2008 | 07:45 PM
  #35
Choreo's Avatar
Choreo
Congtrats again
Thanks again for all your feedback!
Old Nov 9, 2008 | 03:39 PM
  #36
Choreo's Avatar
Choreo
FYI - Here are a couple photos of the original engine removed...
