Clutch problem!!!!!!!!!!!!!!
Old Jan 11, 2002 | 11:18 AM
Garceeya's Avatar
Garceeya
Default Clutch problem!!!!!!!!!!!!!!
I have the Spec Stage III. Have about 7 runs at the track and others on the highway. Maybe around 7-10k miles on the clutch. Raced a fast butt Supra yesterday and the clutch pedal stuck to the floor. I have seen others have this problem. I can not believe I paid for a stage III clutch and an install from hell to have these problems. Any suggestions. I am going to talk to my performance shop and see if they can help me out here. What do you think Spec should do?
Old Jan 11, 2002 | 11:30 AM
The One's Avatar
The One
Default Re: Clutch problem!!!!!!!!!!!!!! (Garceeya)
Sorry to hear about the issues, Greg. Did you just replace clutch/pp? The problem is likely in the hydraulics.
JC
Old Jan 11, 2002 | 11:32 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I went through a lot of clutch problems in the past year and one of them was very similar to this when I had a z06 clutch in the car. The pedal would stick to the ground under hard acceleration. I switched out all the hydraulics and it did not improve anything.
I would say the problem is the pressure plate. I believe the STAR clutches all use a modified stock pressure plate. I know of quite a few STAR nightmares just like this. I hear the Cartek Pressure Plate works pretty good with the STAR disks. That might be a consideration.
Old Jan 11, 2002 | 12:11 PM
chuckster's Avatar
chuckster
Dude, here is your FIX, Period..
The GM Hydraulics Blow Goats! It's not the Clutch.
http://forums.corvetteforum.com/zerothread?id=214330
[Modified by chuckster, 10:11 AM 1/11/2002]
To Clutch problem!!!!!!!!!!!!!!
