fog lights dont work?
Fuse#6 in footwell also runs dash and rear lights.
So again, based on the OP's description of the indicator light being on, the the fog lights not illuminating, it suggests the following:
1) Minifuse #6 in the IPEC is good
2) Minifuse #6 in the UEC is good
3) Minifuse #32 in the IPEC is good
3) The BCM is receiving a fog lamp request via the switch
4) The BCM is providing a ground for the fog lamp relay
So that leaves:
1) The fog lamps themselves
2) Wiring from the load side of Minifuse #6 in the UEC to the fog lamps
3) Ground G102 or SP100
