What Valve Stem Seal LS6
Old Nov 2, 2008 | 07:52 AM
RaleighSS's Avatar
RaleighSS
Default What Valve Stem Seal LS6
I am about to order a new set of Valve Stem Seals for my 2002 Z06 ... She has a G5X2 equivalent cam and double springs on a otherwise stock motor.... COMP cams has 2 types of seals Umbrella type and O-Ring type..... Any Idea which one I should order?
http://store.summitracing.com/partde...art=cca-502-16
http://store.summitracing.com/partde...art=cca-501-16
Old Nov 2, 2008 | 10:57 AM
lucky131969's Avatar
lucky131969
I used positive stop type.
Old Nov 2, 2008 | 11:53 AM
RaleighSS's Avatar
RaleighSS
Default ??
What is the positive stop type?
Old Nov 2, 2008 | 12:33 PM
lucky131969
Ahhh, the type used on our heads.....
http://www.ls1howto.com/howto/fbody/...trainparts.jpg
Old Nov 2, 2008 | 01:03 PM
RaleighSS's Avatar
RaleighSS
Default ok
Now i am confused Comp cams does not list the positive stop type for the LS6 which is a 11/32 valve.... they have only two types that do not require mods to the heads...
http://www.compcams.com/Products/296-320.PDF
Old Nov 2, 2008 | 04:39 PM
Thickraybans's Avatar
Thickraybans
I've used several types of seals & had the best luck with the GM seal,in the link in Lucky's post.
I use the exhaust seal on all sixteen stems.
Old Nov 2, 2008 | 05:05 PM
RaleighSS's Avatar
RaleighSS
Ok...... still not sure what way to go .... Any one used the comp cams one set?
Since i have double valve springs does it make a difference if i use stock ones?
Old Nov 2, 2008 | 05:09 PM
Thickraybans
The GM seal is fine with dual springs
Old Nov 2, 2008 | 05:22 PM
lucky131969
I used the stock (brown) exhaust valve seal on all 16, I have patriot gold doubles.
Old Nov 2, 2008 | 06:27 PM
vettenuts's Avatar
vettenuts
They are not 11/32 valves, they are 8 mm. If you are going with a beehive spring, the stock one piece GM seal/seat is fine. If you are going with duals, get the older GM seal design which is an umbrella type that uses a separate seat.
Old Nov 2, 2008 | 10:02 PM
lucky131969
Why?
Old Nov 3, 2008 | 01:50 PM
cam99's Avatar
cam99
Why?
Why? Shouldn't use Umbrella with Duals, Umbrella may come into contact with the inner spring and eventually fail.
Positive Seal is the way to go. Exhausts for all 16 valves.
Old Nov 3, 2008 | 03:39 PM
RaleighSS's Avatar
RaleighSS
Default :)
So I called the dealer ... they have 8 intake and 8 exhaust in stock..... I should only get the Exhaust because the Intake ones are Umbrella?
Old Nov 3, 2008 | 04:17 PM
cam99's Avatar
cam99
They are all Positive Seal, no Umbrella.
You can use 8 Exh and 8 Intake Positive Seals, but if you wanted to be more conservative, you can also use exhaust seals on the Intake valves, too. Your choice.
To What Valve Stem Seal LS6
