Fastest NA setup?
Old Nov 3, 2008 | 10:26 PM
guitar420911's Avatar
guitar420911
Default Fastest NA setup?
What is the most hp/tq that anybody has seen with a NA setup?
Old Nov 3, 2008 | 11:20 PM
SearayC5's Avatar
SearayC5
Are you talking about the stock 346 cu. in. engine?
Old Nov 3, 2008 | 11:24 PM
SlowFRC's Avatar
SlowFRC
I hope so because if not then this question is ridiculously open-ended.
Old Nov 4, 2008 | 08:34 AM
LDB C5's Avatar
LDB C5
Numbers in sig. I am quite sure there are a lot of guys out there with more. With a little luck, I should be freeing up a few more over the winter
Old Nov 4, 2008 | 08:43 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
My car has 585 tq NA 447..
Old Nov 4, 2008 | 08:55 AM
LDB C5's Avatar
LDB C5
Originally Posted by chris@east coast supercharging
my car has 585 tq na 447..
what????
Old Nov 4, 2008 | 08:56 AM
9secondflat's Avatar
9secondflat
532 rwhp n/a
Old Nov 4, 2008 | 09:03 AM
OLD-GUY's Avatar
OLD-GUY
From: *MIDDLETOWN NY* "I thought I was an OLD-GUY, till I met Charlie"
420 CI---------- 545 RWHP--------505 RWTQ
Built by ECS
Old Nov 4, 2008 | 09:16 AM
guitar420911
Yes, the stock LS1 or LS6.
Old Nov 4, 2008 | 09:17 AM
Cruise-In V Veteran
Originally Posted by LDB C5
what????
I cant find the 585 sheet but I had a 595/585 pull..
Old Nov 4, 2008 | 09:23 AM
LDB C5's Avatar
LDB C5
I think the OP was interested in STOCK CUBE engines
Old Nov 4, 2008 | 09:35 AM
nickolbag's Avatar
nickolbag
A few have broken the 500rwhp mark. Cartek, ECS, Vengeance. Cartek went mid 10s in a Vette and low 10s in TA. Not sure on the others times.
Old Nov 4, 2008 | 09:59 AM
SlowFRC's Avatar
SlowFRC
If we are talking about stock displacement ls1/6's then I don't think any have cracked the 525rwhp mark and 475rwtq mark and that is being generous (probably more like 450rwtq. As for times at the track, TSP set the record for a tock displacement LS1 at the LSX shootout this year, they ran a 9.8x if im not mistaken. Now keep in mind this car was completely gutted and weighed 2,800 or 2,900lbs they still got in the 9's regardless. Also Robz got in the 9's with his (claimed) stock displacement n/a ls6. There is some controversy surrounding whether he did this n/a or not but according to him it was done completely n/a.
Old Nov 4, 2008 | 11:23 AM
99 vett babycar's Avatar
99 vett babycar
Chris, be advised. I'm currently finishing up the install of a surplus F 16 engine.
Old Nov 4, 2008 | 11:26 AM
Cruise-In V Veteran
Sorry if I missed it but I didnt see that in the post.
Old Nov 4, 2008 | 11:27 AM
Cruise-In V Veteran
We went 10.70 in a pretty heavy vert.
Old Nov 4, 2008 | 03:51 PM
robz's Avatar
robz
My highest corrected dyno numbers were 467rwhp on a mustang dyno which converts to around 525-530rwhp dynojet.
I have backed up these numbers on the strip.
To Fastest NA setup?
Old Nov 4, 2008 | 04:27 PM
SearayC5's Avatar
SearayC5
The highest I've seen is 480 rwhp.
Old Nov 4, 2008 | 05:14 PM
LDB C5's Avatar
LDB C5
I guess I am doing better than I thought I hope to free up another 15 or 20 over the winter
Old Nov 4, 2008 | 05:42 PM
robz's Avatar
robz
The best numbers I've seen have seen with no tricks have come from great aftermarket heads. Trick flow heads, ETP, and AFR.
