What is this engine missing?
Old Nov 11, 2008 | 12:45 PM
burnin red's Avatar
burnin red
Default What is this engine missing?
thinking about buying this 2002 z06 what do you think is missing on the engine, intake, throttle body, maf sensor, air intake, anything else? can you guys see anything else that I am not thinking of?
Old Nov 11, 2008 | 01:58 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It depends on what its going into. For example, there aren't any knock sensors there.
Chevy Guy's Avatar
Chevy Guy
Piston pull back springs.
Old Nov 11, 2008 | 02:10 PM
burnin red's Avatar
burnin red
it is staying in the car, i just wonder what parts i am going to have to buy
Old Nov 11, 2008 | 02:27 PM
KCvetteowner's Avatar
KCvetteowner
Burnin Red,
Any chance this car is in KC so I could look at it with/for you?? What is the seller advertising this as?
Observations:
- Lets say it's a 2002 Z06
- Those aren't LS6 heads, that's not a LS6 valley cover (as mentioned above no knock sensors.) What's been done with the motor? Is this an LS2/LS3?
- Where's the top of the motor?
- He's running the green stuff for coolant
- The top radiator hose doesn't look like it's on all the way??? wth?
- aftermarket plug wires
- cut out radiator shroud - that's a first for me...
- Don't tell me that's the AC accumulator out there at the side of the motor??
So you need to figure out:
- Is it an LS6 motor? What heads are on it, cam etc.
- the valley cover and where the knock sensors were moved to.
- Intake/gasket + map sensor
- Injectors
- A.I.R. plumbing??????? Was it removed?
- tb/gasket
- Hose from tb to valley cover
- Air couplers, MAF, Air intake
- I assume the fuel rail is okay laying to the side
- There are two sensors at the back of the block just beyond the valley cover: cam position sensor and the other is the coolant temp I think. Make sure they are both there. Coolant temp is a pita to remove later so you may want to just install a new one if the car has 40k miles or more.
- Due to the hack job on the radiator shroud and the AC accumulator location I would seriously wonder what else has been hacked up or duct taped.
Paul.
Old Nov 11, 2008 | 03:21 PM
burnin red's Avatar
burnin red
no the car is in minnesota, 1 owner original 20,243 miles
I think it may have had a magnacharger on it then they just took it off, the car was repoed so who knows,
Old Nov 11, 2008 | 03:22 PM
burnin red's Avatar
burnin red
and it is 2002 z06
Old Nov 11, 2008 | 03:29 PM
KCvetteowner
A magnacharger wouldn't require new heads but perhaps the owner upgraded....
You would need to get the head and block casting numbers to figure out what you've got there. It's not what they think it is.
Here is what a genuine 2002 LS6 motor looks like (it's mine). Notice the area between the intake ports where the head bolts are compared to your photos above.
Old Nov 11, 2008 | 03:40 PM
burnin red's Avatar
burnin red
yep your right looks totally different, hard to figure out what everything is, without actually seeing it in person, I have a bid in know to buy it.
so I will know today if it is mine, hopefully it is built and bad to the bone
I will let you know if I get the car today, thanks for the help Paul, you may have to make a trip down to the lake to help me figure this thing out
Old Nov 11, 2008 | 03:41 PM
lucky131969's Avatar
lucky131969
That old sock wrapped around the breather is turn off for me
Old Nov 11, 2008 | 03:42 PM
burnin red's Avatar
burnin red
do you think they are after market heads?
from my experience a car like this one owner with only 20k miles may have a ton of money into it you never know?
burnin red's Avatar
burnin red
for sure it looks great on there ha ha
Old Nov 11, 2008 | 04:52 PM
intoc6s's Avatar
intoc6s
If you get it for a good price, that would be awesome! It would be easy to get running! I never liked working on my T/A s and Camaro s, like i do these Vettes! (you got me feeling like its mine....almost)
Old Nov 11, 2008 | 07:02 PM
Chevy Guy's Avatar
Chevy Guy
Buying that car, in that condition, it better be a damn good price. Way too many unknowns with that thing. Looking at a couple grand to get an engine running that might not be any good, and who knows what else can be wrong.
Old Nov 11, 2008 | 07:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
So,,,,,your buyin a pig in a poke. You dont even know if the engine runs or what mody has been done or need to be UN DONE? Man,,, your brave.
Old Nov 11, 2008 | 07:33 PM
Chevy Guy's Avatar
Chevy Guy
And from what I see, that car didn't have a magncharger or any other SC on it. The fuel rails are still OE with the crossover that fits in the groover in the manifold, and they only fit a OE or other OE style aftermarket manifold.
Old Nov 11, 2008 | 09:03 PM
vettekidc5's Avatar
vettekidc5
I spy a LS2 block.... Anyone Digg?? Youll be getting a 6.0L at the minimum.. It also could be stroked out depending on the kit and overbore it could bt a 408, 416 424
If youll look close youll see theres a real thick aftermarket radiator in there, Stock is thin. It also has wires running to the front for some electric frans probally.
That shroud was cut most likely for fatter pipeing instead of an air bridge and make it clear the hood. Its not a big deal.
The sock over the catch can is not a big deal, That keeps oil mist from spraying everywhere..
I think someone might have had some expensive manifold on it and took it off and sold it seperate...
To What is this engine missing?
Old Nov 11, 2008 | 09:55 PM
Chevy Guy's Avatar
Chevy Guy
Good point, makes sense as far as the heads go, the heads are the LS2 design.
The LS2 didn't use that fuel rail though.
I would also pull the heads before reassembling the top end. Imagine a washer or nut in a cylinder at start up?
Old Nov 11, 2008 | 11:49 PM
vettekidc5's Avatar
vettekidc5
true, But if it was swapped in they would have kept the Stock fuel system intact, and probally used a Fast 90 setup, Where that rail would need to be used without the converstion kit for the LS2 rail. The fast 90 was designed for the LS1 rail initally.
That shroud was probally cut for some intake.. You could leave it be or simply replace it, its not hard to do 4 little botls.
Old Nov 12, 2008 | 10:30 AM
burnin red's Avatar
burnin red
so what kind of intake do you think would have to be put on the car for it all to hook up correctly?
