Retune after porting FAST??
Old Nov 16, 2008 | 09:06 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Default Retune after porting FAST??
Thinking about porting my FAST intake, would I need to tune after or would it be a waste of time/money?? LMK...
Old Nov 17, 2008 | 12:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Chad
You have a tune from ONE OF THE BEST IN THE BUSINESS (SLOWHAWK)> I'm quite sure that porting the intake will increase intake efficiency but, it's difficult to say how much it will effect the Volume metric Efficiency (VE) tables. Thats the major thing thats going to change if you port your manifold. I recommend you contact Tony Mamo and ask him what he recommends, Hes very honest and straight forward and will lead you in the correct direction. I'm sure SLOWHAWK will top off your tune if its necessary.
On second thought, NA,,,don't tune it. That way it will be easier to have any chance to beat ya!
Who's going to port your manifold????
Bill C
Old Nov 17, 2008 | 10:02 AM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Thanks BC!!!
I have already talked to Tony Mamo, and he suggested I go with a whole new ported 92 setup. Obviously, I would need to retune after that, but I am not going that route when Mamo's tests have shown only a 5hp gain over my current FAST 78 setup. That would be a lot of $$ for very little gain!!
I will pm Don and see what he thinks!!
As for outrunning me, I don't think your clutch will let you!!
Old Nov 17, 2008 | 10:06 AM
vettekidc5's Avatar
vettekidc5
I wouldnt retune yet, wait till u get more mods then retune.
And-
Ill get you both!!!
Old Nov 17, 2008 | 12:34 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
And-
Ill get you both!!!
I really can't do any more mods than my current full boltons, stage 2 heads, cam, and nitrous...unless I went anther route all together!!
And...I doubt it!!
Old Nov 17, 2008 | 02:26 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Chad- I would definitely have the AFR checked after the port work especially if you did serious porting to the FAST. A few years ago after my h/c was done, I purchased a breathless performance air duct and installed it...i said to myself that little part swap wont do jack to my tune. I then happened to go to a dyno day at some other tuner shop My afr was leaned out some! Took it back to ECS and Chris made some adjustments to the fuel and it was back to 12.9
Old Nov 17, 2008 | 06:19 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
And-
Ill get you both!!!
CHAD,, "MORE MODS!!! That would mean duel turbos or a supercharger!
Chad
I have decided to get a SPEC duel disk and I will install it this winter. That should take care of that small issue!
BC
Old Nov 17, 2008 | 09:41 PM
CRV3TT3's Avatar
CRV3TT3
Thanks BC!!!
if you only stand to pick up 5hp with a ported 92, what would porting you 78 get you? 2-3hp??
Old Nov 18, 2008 | 10:14 AM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
No, the ported 90 only yeilds 5 hp more than the ported 78 overall. Not only a 5hp gain. I forget what the overall gains were, something like 20whp for a 78, and 24-25whp for a ported 90.
Old Nov 18, 2008 | 10:21 AM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Found this reply from Tony Mamo in another thread...
Originally Posted by Tony Mamo @ AFR
Russ...
Your ported 78mm FAST will make 5 HP more than an out of the box 90mm....unless you port the 90 as well you will be going backwards. You will only see a 5 RWHP bump in power with the 90mm ported but your throttle response will improve dramatically.
When the smoke clears on the dyno however, the difference between one of my ported 78 units and ported 90's isn't very much. There is probably a better way to allocate those funds IMO....your going to spend alot of money for 5 ponies or so (ported 90 mm intake plus ported LS2 90mm TB, etc.).
My original 346 build made 475 RWHP with the ported 78 FAST....480 with the addition of the larger 90mm unit.
If your starting from scratch I feel the 90 is a good move....but already invested in a ported 78 its probably not unless you simply have to have every last pony and are willing to pay for it (or have a buyer giving you a decent buck for your original set-up).
Keep the 78 set-up, get a larger cam, add some compression, fly cut your pistons, and run a set of Yella Terra ultralite rockers....that will certainly wake up your combo.
If you need some advise you know where to find me...
Tony
To Retune after porting FAST??
