Water pump replaced!!!
Old Nov 23, 2008 | 03:41 PM
DAYUIZ's Avatar
DAYUIZ
Default Water pump replaced!!!
For the past two weeks I've had a pretty bad leak from somewhere under or behind the water pump. So I did a little research on my favorite corvette forum and found that most said it was pretty easy to swap out the water pump.
It took me two hours and a 10mm wrench and socket and the job was done in the driveway. About a half hour of that was spent cleaning the front of the block with a toothbrush and soapy water.
I just want to say thanks again to the forum and for those that shared their know-how with the rest of us.
-Steve
Old Nov 24, 2008 | 09:15 AM
Gideon's_Test's Avatar
Gideon's_Test
Glad you got it fixed without too much trouble.
