roller lifters which ones
Old Nov 25, 2008 | 11:33 AM
LSX4LIFE's Avatar
LSX4LIFE
Default roller lifters which ones
Going to be installing a h/c over the winter in a 2000 cpe.
I hear that the ls7 are good, ctsv are good, comp cams have good ones etc. Any ideas which one to use. curt
Old Nov 25, 2008 | 11:43 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
I know the LS7 lifters are good to 7000 rpm and have been used with a lot of success. Good thing is they are pretty inexpensive.
Old Nov 25, 2008 | 12:30 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
The LS7 lifters are fine. The Cadillac racing are really only needed for very high rpm setups.
Old Nov 25, 2008 | 02:21 PM
lucky131969's Avatar
lucky131969
Can't go wrong with LS7's
Old Nov 25, 2008 | 02:36 PM
OhioC5's Avatar
OhioC5
I think the LS7 are the standard replacements anyway.
Old Nov 25, 2008 | 02:48 PM
vettenuts's Avatar
vettenuts
There have been a number of failures on the Cadillac lifters, which seems to be a function of the valve train setup (spring loads, valve weight, etc.). If you are looking for the top shelf, they are Morel and the Crane billet. Everything else is a step below but many are running LS7 without problems. It really depends on your proposed valve train setup.
Old Nov 25, 2008 | 05:08 PM
lucky131969
Morel lifters makes sense for a car that will see extended high rpm use i.e auto-xing, but they are overkill for a street car that only sees the strip a few times a year.
Old Nov 25, 2008 | 05:46 PM
vettenuts's Avatar
vettenuts
Not really, depends on the setup. Many are now running very high spring rates and seat loads to control larger and heavier valves. Higher cam ramp rates contribute to lifter loads as well. Comparing materials, extended RPM is not the only criterion I would use in choosing a better lifter. Also, both Morel and Crane billet are designed to sit lower in the bore due to the smaller base circle of aftermarket cams, the LS7's are not.
Old Nov 25, 2008 | 06:26 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
bingo, LS1,2,3,6,7 are one and the same
www.gmpartshouse.com for the best price/service; ordered a bunch of sets from Gene
Old Nov 25, 2008 | 07:50 PM
lucky131969
Well, after reading how you "pumped up" morel lifters (pun intended ) a couple of months ago on LS1Tech, I figure you must have installed them in your motor. I still don't know what anyone gains by using these lifters for a street car, and I doubt anyone can show me in reliability or on a dyno (for a non race car). Hell, I'm still waiting for someone to post the performance gain from adjustable rockers.
Old Nov 25, 2008 | 08:02 PM
vettenuts's Avatar
vettenuts
I don't view them as a performance gain (not much to be gained by lifters) but rather a reliability increase when higher valve spring forces, faster ramp rates and higher lift (smaller base circle) cams are used. I used them in my old setup and for my new setup just completed I had them rebuilt with new rollers and bearings (another feature of Morels is they are fully rebuildable).
Old Nov 25, 2008 | 08:06 PM
lucky131969
That's what I figured......
Old Nov 25, 2008 | 08:53 PM
CTD's Avatar
CTD
I had issues with my Cadillac Racing Lifters right out of box, the problem is visual. My attraction was the design difference which is suppose to help reduce valve train noise, don't ask me what that was I don't remember....something to with the position of a oiling hole. The second was of course the high RPM stability when auto X & don't want to shift...combined with the Ultra lite rockers. I would do the CRL again just be a bit more prudent with out of box inspection.
Old Nov 26, 2008 | 04:33 AM
C5Spirit's Avatar
C5Spirit
I have the Caddie racing lifters, Yella Terra rockers, ZO6 cam and Patriot 62cc heads. Vortech supercharger 10# of boost 556 RWHP/ 511. RWTQ and so far no problems from the caddie lifters. Guess I'm lucky
Old Nov 26, 2008 | 09:12 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Steve,
are you saying that the LS1,2,3,6,,&7 lifters are all the same? as in the same part number?
or that the LS7 lifters are a direct (and reccomended) replacement for any LSx?
Old Nov 26, 2008 | 10:42 AM
LSX4LIFE's Avatar
LSX4LIFE
I just want to know then if the ls7 lifters or the same as ls1 why change then
Old Nov 26, 2008 | 10:58 AM
0HinsonSuperCars
Former Vendor
The LS7 lifters are a direct replacement for all LSx engines. If you have some miles on your current ones and your doing heads & cam, it's a good idea to replace them.
To roller lifters which ones
Old Nov 26, 2008 | 11:47 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
If you want a good lifter put in Morels.
Old Nov 26, 2008 | 02:07 PM
SteveDoten's Avatar
SteveDoten
Originally Posted by Capthuff
Steve,
ALL SAME
most shops use them
Old Nov 26, 2008 | 06:14 PM
ILM-Express's Avatar
ILM-Express
MFIC
same part numbers ????
ALL SAME
most shops use them
