cam suggestions
Old Nov 27, 2008 | 01:11 PM
jaygood's Avatar
jaygood
Default cam suggestions
With a 2800 converter, what size cam should I go with? I have a 2000 a4 w/ 3:15s
Old Nov 27, 2008 | 01:28 PM
falcon5619's Avatar
falcon5619
What are you plans for the car? Street only, Strip, Autocross?
Where do you want to make additional power? Across the entire power band? Do you want to make more peak power up top but lose some down low?
How about idle? Do you want a silky smooth idle or some chop and shake?
If you don't know then a good middle of the road cam should have an intake duration in the 220s on a 114 LSA. This will provide a good balance of drivability and increased power across the entire power band.
Old Nov 27, 2008 | 01:42 PM
zeevette's Avatar
zeevette
Good all-around cam....224-228@114. Nice wide powerband, and good gains.
Old Nov 27, 2008 | 01:59 PM
falcon5619's Avatar
falcon5619
Same one I just put in.
Old Nov 27, 2008 | 02:50 PM
Bluefire's Avatar
Bluefire
I have an 03 A4, 3:42, 2800 stall. I am considering this sized cam with AFR heads next spring. How is the idle rpm? This is my DD but, I do want some lope. Does the 114 LSA have a decent lope?
Old Nov 27, 2008 | 03:09 PM
z06 hellcat's Avatar
z06 hellcat
it's much harder to make yellow go fast, i would buy a blower,,!!!
Old Nov 27, 2008 | 06:38 PM
falcon5619's Avatar
falcon5619
The idle is great. I left it at the stock 800rpm idle on the Z06. It definitely has some lope and shake to it over the Z06 cam. Nothing crazy, but anyone that knows anything about cars will be able to tell it is cammed. If you want more lope, just set the idle at 750.
I think if you stay on a 114 you will be happy. Great for a daily driver but a little lope and shake so you know it has a bigger cam in there. It seems to be the sweet spot on these engines.
Old Nov 27, 2008 | 08:51 PM
vettenuts's Avatar
vettenuts
If you mill for compression the 112 LSA with this cam may put you too close on PTV. I have it on a 114 and barely made it. Nice cam on a 114 though.
Old Nov 27, 2008 | 09:42 PM
VIPERBLUELX's Avatar
VIPERBLUELX
how much did you mill? I have .040 gaskets and a 230/228 112 and it had plenty of clearance
nevermind i see this is with AFR heads
Old Nov 28, 2008 | 02:44 AM
Bluefire's Avatar
Bluefire
Thank you for the information. It sounds like it is just what I am looking for.
Old Nov 28, 2008 | 02:47 AM
Bluefire's Avatar
Bluefire
I think I will stick with the 114 LSA.
To cam suggestions
