LS2/LS1 intake
Old Nov 28, 2008 | 12:58 PM
188CORVETTE's Avatar
188CORVETTE
Default LS2/LS1 intake
are these intakes interchangeable on the LS1? If so is the LS2 a 90mm?
Old Nov 28, 2008 | 01:38 PM
vettenuts's Avatar
vettenuts
Yes, but the LS2 does not perform as well as the LS6 unless you have it ported. Best getting the LS6 IMO.
Old Nov 29, 2008 | 07:22 AM
kjmj's Avatar
kjmj
Old Nov 29, 2008 | 11:50 AM
188CORVETTE
so an even better setup would be fast 90 with a ported and polished LS2 t/b?
Old Nov 29, 2008 | 11:52 AM
Mike94ZLT1's Avatar
Mike94ZLT1
yes but unless you have all the supporting bolt ons, a healthy cam and heads, you are wasting your money.
Old Nov 29, 2008 | 01:14 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is a shoot-out of all the manifolds including the LS2 versus other LS series manifolds
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
Enjoy - it's a good article
Thanks,Matt
Old Nov 29, 2008 | 01:38 PM
gleds's Avatar
gleds
Thanks,Matt
Great article. It looks like the LS6 intake w/90mm TB is the best bang for the buck. No doubt the fast is the best performer though.
Old Nov 29, 2008 | 03:20 PM
vettenuts's Avatar
vettenuts
There is a new one due out by Weiand but it is months late and no results on it yet. Might be worth looking at to see if you want to wait for it over the winter.
Old Nov 29, 2008 | 05:42 PM
fst85vtt's Avatar
fst85vtt
If you look at the tpis testing the ls2 intake and ls2 90 are a very big cost effective improvement over the stock ls1/75mm t/b I would have to say bang for the buck the ls2 is the way to go and also this is unported Hell Ive seen ls2 intakes go for 150 while the ls6 may have 5-8 hp on the ls2 in some areas Bang for the buck you cant deny that the ls2 is your best bet Hell I just noticed that it actually outperforms the ls6 at 6600 and that is about where I want to shift
Old Nov 29, 2008 | 05:46 PM
fst85vtt's Avatar
fst85vtt
What is needed to install the ls2/90 t/b Ive seen the adapter harness for the t/b what about fuel rails and such?
Old Nov 29, 2008 | 06:14 PM
tlc0706's Avatar
tlc0706
Well, that was an interesting article....Thanks Matt
Old Nov 29, 2008 | 07:58 PM
188CORVETTE
Thanks,Matt
Wow! again the forum members come through with great info!
answers alot of questions, thanks
Old Nov 29, 2008 | 08:20 PM
fst85vtt's Avatar
fst85vtt
Obviously if you have an ls6 intake your not going to switch to an ls2 but if your like me with an ls1 The ls2 has a large hp/tq increase over an ls1 intake..
it would be nuts to buy a ls6 then spend money to put a 90 t/b on then i would go the fast route
Old Nov 29, 2008 | 10:50 PM
petercln's Avatar
petercln
I had a ls2 intake and t/b put on my ls1 and picked up about 40 hp.
But that was at 14+lbs of boost. Seriously it the best bang for the buck. Split the fuel rails and make the balance tube longer(steel braided line). And buy the t/b wire adaptor. You can even still use your ls1 frc.
Old Nov 29, 2008 | 10:52 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
only if you have a cam.. other wise it is a waste of cash
Old Nov 30, 2008 | 08:41 PM
188CORVETTE
yes going with big cam, want to make power all the way to 7000. This is a road race LS1 stage 2 TEA heads, dry sump, forged bottom end, 42lb injectors, etc. Just need to get this intake dialed in
To LS2/LS1 intake
