harmonic balancer puller and lifter rod tools question
Old Nov 28, 2008 | 03:52 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Default harmonic balancer puller and lifter rod tools question
Just trying to get all my ducks in a row before my cam gets here. Ordered all the gaskets, seals, LS2 timing chain, and ARP crank bolt today. I'm going to make my own pulley install tool. What's everyone using to pull the stock balancer off? Also I'm aware there are rods to hold the lifters up, but I've heard of using wooden dowels? Anyone know what diameter I'd need and where to get them?
thanks
Mark
Old Nov 28, 2008 | 04:25 PM
VIPERBLUELX
While we're at it, what size flare nut wrench is needed for the power steering rack hoses?
Old Nov 28, 2008 | 04:35 PM
vettenuts's Avatar
vettenuts
Flare nut size - 18mm
Rods - Get 5/16 metal from Home Depot (see below), broken wood is too big a risk to save a few bucks.
Pulley installer - M16X2mm, 300mm long with nuts.
Old Nov 28, 2008 | 04:48 PM
VIPERBLUELX
what are you using to pull the balancer off?
Old Nov 28, 2008 | 04:54 PM
vettenuts's Avatar
vettenuts
For the stock one I rented a three jaw puller from Autozone.
Old Nov 28, 2008 | 06:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Vettenuts has this procedure aced! I live close to him and borrowed his install tool... Since then,,,I made my own. Just remove the old damper bolt and once its out,, saw the head of the damper bolt off. Once you have the headless bolt, find someone that will weld it to a common piece of all thread. Then add the washers and nuts.
To help get the old damper off,,use heat!!!!!! You can use a heat gun or a torch. Just heat the "HUB" up to about 150-200 deg. Once its warm,,,it will slide off a LOT easier.
Install is the same. I used a heat gun (Wagner paint stripper gun) to heat up just the hub a and it went on really easy. Some put it in the oven and warm it up to 200 deg.
I also pinned the crank. I used a POWERBOND Damper (it has a key way) and side pinned the crank. I was amazed how easy it was.
To get the damper off or to reinstall it, you have to hold the damper. There are two ways. I used a large strap wrench and it worked excellent.
If your not going to use your old damper, here is a handy method. Mine was sooo tight that I was having trouble getting it off. Use a LARGE pipe wrench to secure the damper outer ring:
It worked fantastic.
BC
Old Nov 29, 2008 | 09:47 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
pretty much all the 3 jaw pullers are big POS's, use the OTC GM crank pulley remover, about 70$
it's an awesome tool
I just saw Bill's post above, Bill does NOT get stuck in a task, his method will work as he posts from experience, I prefer the OTC tool
Old Nov 30, 2008 | 03:27 AM
bdiddo's Avatar
bdiddo
rent or buy a snap-on puller. it makes the job a piece a cake. tried two other brand names that turned out to be a pos but the snap on tool was great
Old Dec 3, 2008 | 01:43 PM
Kurtomac's Avatar
Kurtomac
as for the flare wrench....if you can find a stubby....thats the way to go....getting the nut loose i was fine with the standard length flare wrench but tightening it...didnt feel like i could get it tight due to lack of room to move the wrench....stubby cured this problem
also bought a pulley installer over on LS1tech....35 bux well spent
Old Dec 3, 2008 | 01:56 PM
iced98lx's Avatar
iced98lx
doing this in a week as well..
Old Dec 9, 2008 | 02:53 PM
VIPERBLUELX
cam is in, buttoning everything up now!
Old Dec 9, 2008 | 07:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When I first started mine up after the Heads/Cam Mod, it was on OPEN HEADERS!! OMG was that wicked cool! The wife said it shook the dishes in the kitchen!
You just have to do that just ONCE!
Good luck
BC
Old Dec 9, 2008 | 07:57 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Did you run it for 20 minutes like that in the garage to break in the cam?
I bet that did sound bad
Old Dec 9, 2008 | 08:00 PM
VIPERBLUELX
I drove mine 20 miles with open headers to get the mid-pipe fabbed up when I first did the headers.
Old Dec 9, 2008 | 08:25 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No break in like that needed with roller cams....that's a flat tappet thing.
Old Dec 9, 2008 | 08:38 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
oh yeh, I knew that. Really, I did.
To harmonic balancer puller and lifter rod tools question
