turn signals
Old Dec 1, 2008 | 11:22 AM
togan's Avatar
togan
Default turn signals
i have a 2002 and my blinkers work when they want to. please help if you can
Old Dec 1, 2008 | 11:27 AM
timemender's Avatar
timemender
Try cycling (On – off – on – off) the hazard switch SEVERAL times to “clean” the contacts of the hazard switch. Turn signals run through the hazard switch. (Somewhat common problem)
Keep us updated with your results.
Old Dec 1, 2008 | 11:41 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Replace the hazard switch is the only sure fix. For under $50 and a little over an hour of your time the problem will be gone. Do a search on hazard switch will pull up past postings with photos on how to change it out.
Regards,
Eric D
To turn signals
