Need Performance Help
Dec 2, 2008 | 04:01 PM
I filled out the signature
Dec 2, 2008 | 04:10 PM
St. Jude Donor '12
Quote:
Originally Posted by
snook02
I have a 3.42 thanks for the help what should i upgrade to
3.90's or 4.10's unless you plan to supercharge the car.
Dec 2, 2008 | 04:16 PM
So i should do
Cam
Gears
Clutch
Does that sound right am I missing any thing
Dec 2, 2008 | 04:19 PM
snook02
So i should do
Cam
Gears
Clutch
Yeah. I advise you to find a good shop/tuner in your area so you can discuss your performance goals, and what works within your budget.
Don't let members of the forum make choices for you.......
Dec 2, 2008 | 04:21 PM
D0 you know any good shops in LA. state or around New Orleans area
do u know anything about Thunder Racing
Dec 2, 2008 | 04:30 PM
Also, find out what they are doing for the money. Saving money by someone slapping in a cam without degreeing it or checking basics such as wipe pattern, lifter preload, etc. is false economy. These are time consuming steps and make the difference between good and great results for any given setup. Don't shop by price alone. Granted I don't do this every day, but it took me a few hours to set the wipe pattern (I work slow and take my time) so you can see that the labor hours would add up quickly if everything is done right.
Dec 2, 2008 | 04:39 PM
snook02
So i should do
Cam
Gears
Clutch
Looks like you're headed in the right direction. Also, I hear nothing but good things about Thunder Racing.
Dec 2, 2008 | 04:41 PM
Thunder Racing is really good they did all my mods
Just seemed like there prices were a lil high but i guess that
is the cost of good work
Dec 2, 2008 | 04:54 PM
St. Jude Donor '12
snook02
A good shop is always worth the extra money.
Dec 2, 2008 | 04:56 PM
What does a high stall converter do for you
aslo what is a torque converter ??
Dec 2, 2008 | 04:57 PM
St. Jude Donor '12
snook02
High Stall converter is a type of Torque converter. A torque converter is basically a fluid coupling between the engine and the automatic transmission. Six speed cars don't have them.
Dec 2, 2008 | 07:29 PM
You have a six speed so a high stall does not apply to you. These are for autos.
Dec 2, 2008 | 08:15 PM
so i think i will go with
cam
underdrive pully
injectors
Do you think the stock clutch can hold 400 rwhp
Dec 2, 2008 | 08:18 PM
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
With normal driving the stock clutch should hold up.
If you plan on taking it down the 1/4 a bunch of times - then probably not.
Dec 2, 2008 | 08:20 PM
other than the mods i have done and the cam, under drive pulley, injectors and clutch
I have 3.42 gears
what would be the biggest missing piece to running a good 1/4 mile
Dec 2, 2008 | 08:23 PM
Spray???
Dec 2, 2008 | 08:32 PM
snook02
I have 3.42 gears
Practice.
Dec 2, 2008 | 08:43 PM
what would i run with 420 rwhp
Dec 2, 2008 | 09:01 PM
13.0@118mph. All depends on the driver. 420 at the wheels is good for a ten second pass with a good driver.
