TPMS receiver location?
Old Dec 1, 2008 | 10:13 PM
steelels1's Avatar
steelels1
Default TPMS receiver location?
I have a new style (01-04) TPMS receiver ready to install - I've isolated the pins needed to connect to my older harness according to a thread I saw on here and it's ready to go, except - where is it?
From searching on here, it seems to be on the driver's side, but I don't know what panels to take off. Only thing I've found so far is a silver Antenna Receiver Module on the b-pillar.
I see a "hump" on one of the cargo trim panels but can't figure out how to remove the panel without breaking it (or if that's even what I'm looking for).
Old Dec 1, 2008 | 11:04 PM
wildbadbill's Avatar
wildbadbill
yep.it's above the "hump" bro...
Just pray on that panel down,starting from the end-it's held by doule stick tape... I id it a month ago
Old Dec 2, 2008 | 12:33 AM
steelels1's Avatar
steelels1
Thanks! New keyfobs and tire sensors works great!
Old Dec 2, 2008 | 08:13 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Nice upgrade!
Old Dec 2, 2008 | 04:21 PM
DeeGee's Avatar
DeeGee
Here ya go
Old Dec 2, 2008 | 04:35 PM
steelels1's Avatar
steelels1
Originally Posted by DeeGee
Here ya go
Thanks, hopefully that will help others that find this thread.
Old Dec 2, 2008 | 10:13 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Default ?
anyone care to explain what #2 and #3 is?
It looks like #2 is the receiver, but what's #3?
And,
what did you need to do the swap?
I have a '98 and am waiting for an '01 receiver to arrive-
is there anything else I may need other than the receiver??
TIA,
Tommy
Old Dec 3, 2008 | 07:13 AM
Quicksilver Vert 01
I'd have to agree that #2 is the receiver module.
#3 is probably the receiving antenna for the module.
Old Dec 3, 2008 | 09:36 AM
steelels1's Avatar
steelels1
Actually #3 is the receiver module I was asking about. It has a plastic rod going through the module with foam disks at either end of the rod. I think it's to hold it in place - it's literally under a plastic panel held on by double-sided tape, but I didn't look at it that closely.
#2 is something else - maybe a crash sensor/module?
Old Dec 3, 2008 | 10:01 AM
Quicksilver Vert 01
Good info., Thanks!
Old Dec 3, 2008 | 10:20 AM
timemender's Avatar
timemender
May I ask what this complete conversion cost? (2 fobs, receiver, 4 tire sensors)
Did you use all new parts? Source of parts?
I am still using the original TPMS on my 2000 and plan doing the conversion; most likely this summer.
Old Jul 20, 2009 | 03:10 PM
Gregory0729's Avatar
Gregory0729
I can't seem to locate the receiver in my 98 convertible. Will someone direct me to the correct location?
Edited post to say that I found it!
Last edited by Gregory0729; Jul 21, 2009 at 08:29 AM. Reason: found answer to question.
Old Jul 20, 2009 | 05:22 PM
LoneStarFRC's Avatar
LoneStarFRC
That "plastic rod" is the antenna. Two of them actually. Each pointing in a different direction. The little foam disks are there to prevent the two antennas from wiggling/vibrating against the body panel and making any noise.
To TPMS receiver location?
