Another (different) header question
Old Dec 4, 2008 | 02:23 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Default Another (different) header question
For those of you with long tube headers.
Which do you like and why...
1) The type with the collector flange that bolts to the x-pipe
American Racing, Dynotech, Kooks
2) the type with no collector flange but uses clamps to connect to the x-pipe
LG, Stainless Works, SLP
Old Dec 6, 2008 | 11:21 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Anyone???
Old Dec 7, 2008 | 12:11 AM
snook02's Avatar
snook02
AR headers are the best in the country barnone no question about it
Old Dec 7, 2008 | 01:45 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I've installed several different Headers and the one thing I've learned is that every car is different so a system that has built in adjustment capability can really be a blessing.
The slip fit type provides some lee way with length adjustments and with a good quality bandclamp there are no leak issues.
A Ball and Socket Flange Connector, like on the ARs is great for helping to line up the collectors to the X Pipe if things aren't perfect.
HTH
Old Dec 7, 2008 | 07:14 AM
rws.1's Avatar
rws.1
AR Headers 1 7/8 inch.
Why
Flow/HP
Fit
Finish
Installation ease
Sound
Price
Old Dec 7, 2008 | 11:05 AM
rodknock's Avatar
rodknock
Old Dec 9, 2008 | 12:08 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Thanks for the repies.
I appreciate the input
Old Dec 9, 2008 | 12:18 PM
use2vtec's Avatar
use2vtec
LG, AR, Kooks. Cant go wrong with either of these. All 3 are of the highest quality. I personally run the LGs and they have roughly 30k miles on them with no issues to speak of as of yet.
Old Dec 9, 2008 | 12:35 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
LG certainly have a good rep - as do AR and Kooks.
I was concerned about the slip fit as opposed to the bolt-up flange.
Perhaps my concern was unfounded.
And the sale price LG has for the streets is pretty good right now.
Old Dec 9, 2008 | 01:16 PM
vettenuts's Avatar
vettenuts
I have QTP's which slip fit into Random Tech converter/X-Pipe. There was some minor leakage on one side but a good clamp takes care of it. System has been apart several times without issues as well. From a slip fit standpoint, they seem to work well. Can't comment on the AR type of joint.
Old Dec 9, 2008 | 06:28 PM
motogib1's Avatar
motogib1
Have jet coated melrose headers, not common on the forum but I love em. They use a slip fit and no leaky.
Old Dec 9, 2008 | 06:40 PM
tstar's Avatar
tstar
Melrose makes some great headers!
Tim
Old Dec 9, 2008 | 06:42 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I run kooks 1 3/4" headers with a 3" catted x-pipe... As use2vtec said; between Kooks, LG and AR you really can't go wrong.
I installed the kooks myself in 3 hours using hand tools and jackstands and they have been great ever since... Whichever headers you get, I recommend you get them ceramic coated
Old Dec 9, 2008 | 07:01 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
That looks sharp
Old Dec 9, 2008 | 09:27 PM
PowerLabs's Avatar
PowerLabs
Originally Posted by Capthuff
That looks sharp
And it stays that way for years
But that's not the reason to get them coated... The factory cast manifolds have very thick walls withheat shields on them and don't radiate too much heat; aftermarket headers give off a LOT more heat, which eventually deteriorates everything around them; wires, rubber hoses, spark plug boots, all tend to embrittle over time when exposed to excessive heat. Also, all that heat under the hood ends up heating your intake tract, causing loss of power. Finally coated headers keep the exhaust hot on its way out of the car, maintaining high exhaust gas velocities and thus helping scavenging. One of my main resons for going with kooks was because I could get them from the vendor coated
Old Dec 9, 2008 | 09:59 PM
vetpet's Avatar
vetpet
I went with Bassani. They use a tri-y design that goes from 4 pipes into two pipes into one. This design maintains low speed torque and exhaust flow. They are more expensive than the long tube designs and the quality is top notch. They also are ceramic coated and are a slip fit design with ball and socket collectors which eliminate exhaust leaks. They also provide you with collector flanges for attaching your exhaust to the headers. Easy to install because of the slip fit design. Did it in my garage using jack stands. Nothing wrong with any of the other headers mentioned, just was my personal choice.
Old Dec 9, 2008 | 11:28 PM
VIPERBLUELX's Avatar
VIPERBLUELX
TPIS work well too
To Another (different) header question
Old Dec 9, 2008 | 11:32 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
a lot of good info here.
I was leaning towards the collector flange type because I assumed there would be a real possibility of leaks with the slip-on/clamp type.
It seems, when properly installed, that leaking is not an issue.
Then there is the coating process...
thanks for all your thoughts.
Old Dec 10, 2008 | 01:19 AM
tstar's Avatar
tstar
Yeah good luck deciding! Wait for a nice set in the parts section...
Tim
Old Dec 10, 2008 | 06:32 AM
davisce's Avatar
davisce
American Racing Headers. . . . easy to install, looks great, works great, price is right. . . . and no problems !
