Timing set upgrade
Old Dec 10, 2008 | 10:49 PM
Targa98's Avatar
Targa98
Default Timing set upgrade
What do you all like/dislike about different brands? I am having a hard time deciding. I do not want anything that requires a different timing cover or anything. I am also upgrading my oil pump to this:
http://store.summitracing.com/partde...-10296&FROM=MG
What do you think?
Old Dec 11, 2008 | 09:46 AM
vettenuts's Avatar
vettenuts
I went with the Cloyes Hex-Adjust with the IRL chain (IRL chain is expensive, the standard set has the LS2 chain).
What I like:
1. Cloyes makes the OEM set, so fit is perfect.
2. No double chain issues, no spacers, clean installation
3. Hex-adjust makes cam timing much easier because you don't have to disturb the degree wheel to change timing like a set that changes timing with the crank srpocket
4. Both sprockets are heat treated
5. Made in USA
What I dislike:
1. I would have liked a Torrington bearing, although my original retainer plate had almost no wear so I am not sure this feature would have bought me anything. (Note that Cloyes has/will be introducing this set with a Torrington bearing).
Old Dec 12, 2008 | 01:36 AM
Targa98's Avatar
Targa98
Cloyes really makes the oem stuff eh? that is a major point.. looks like cloyes it is unless someone tells me something terrible
Old Dec 12, 2008 | 05:29 AM
vettenuts's Avatar
vettenuts
Last time I spoke to Mike at Cloyes he mentioned they were testing a new chain that would be an option like the IRL chain was, but it would be less money. Not sure of the status of the new chain. Also not sure of the status of the Torrington setup either.
Old Dec 12, 2008 | 08:06 AM
AMRAAM's Avatar
AMRAAM
I used an LS2 chain. side by side witht eh stock LS1 chain, you could see the difference. It's not a huge difference, but it definitely looked stronger.
To Timing set upgrade
