I keep getting these 2 codes!!!
Old Dec 11, 2008 | 12:56 AM
ricoZg's Avatar
ricoZg
Default I keep getting these 2 codes!!!
For the last couple of months now, I've been getting the P0171 and P0174 codes. They both appear together, usually in the morning when driving to work.
They pop up about 1-2 times a week.
They first popped up after I installed a B&B Bullet exhaust a couple months back, but I've had other aftermarket exhausts before that. Even after I removed the Bullet exhaust and installed a Route 66 exhaust, the codes still intermittently pop up.
What should I be checking?
Mike G.
Old Dec 11, 2008 | 01:13 AM
Bill Dearborn's Avatar
Bill Dearborn
It means that both banks of the engine are seeing a lean condition. Perform the following:Check for fuel contamination.
  1. Inspect the HO2S for proper installation.
  2. Verify the electrical connectors and the wires are secure, and not contacting the exhaust system.
  3. Test for continuity between the HO2S signal circuit and the low reference circuit.
  4. Operate the engine at idle.
  5. Inspect for any missing, loose, or leaking exhaust components forward of the HO2S.
  6. Inspect for vacuum leaks at the intake manifold, throttle body, and injector O-rings and vacuum hoses.
  7. Inspect the air induction system and the air intake ducts for leaks.
  8. Inspect the secondary air injection (AIR) system for leaks, improper air delivery, and for the shut-off valves not closing.
  9. Inspect the crankcase ventilation system for leaks.
Bill
Old Dec 12, 2008 | 12:27 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
My sister's 98 Z28 was doing the same thing and codes. I checked everything and couldn't figure out. I finally changed the fuel filter and noticed it was kinda plugged and to my surprise it was fixed. No more code and it's been almost a year.
Old Dec 12, 2008 | 01:42 AM
Bill Dearborn
My 03 Tahoe did the same thing as well and it was a bad intake manifold gasket.
Bill
Old Dec 12, 2008 | 02:41 AM
golfinz's Avatar
golfinz
I have those exact codes after my cam install and Im told my LTFT are a bit off.
Old Dec 12, 2008 | 05:26 AM
vettenuts's Avatar
vettenuts
My Suburban threw a lean code, as mentioned above it was the fuel filter. If you had the intake tract off, I would check that first.
To I keep getting these 2 codes!!!
