Water Pump Life
Old Dec 13, 2008 | 10:29 PM
LoneStarFRC's Avatar
LoneStarFRC
Not exactly a large enough sample to prove anything. Even the forum doesn't have many water pump problem threads. It is comments like these that keep the unreasonable predjudice against domestic cars alive.
Bil
Old Dec 13, 2008 | 10:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Hey Eddie,..I changed yellowvettes at 60K~ as it was leaking,....I changed the one in my 99 at 93K and it wasn't leaking yet...no ryhme or reason to the life span..
got a replacement from Gene Culley
Old Dec 13, 2008 | 11:31 PM
LT1driver's Avatar
LT1driver
Eddie, nice looking 70 you have there
Old Dec 14, 2008 | 05:00 PM
yakisoba's Avatar
yakisoba
The pump in the LS1 and 6 engine has two shaft seals. Between the inner and outer seal is a weep hole. If you get a little water coming from the water pump, it may be that one of the seals has failed, and the weep hole is doing it's job and telling you by dripping a bit of water on the garage floor. I researched it, and that's the time to replace the pump. It's an easy swap out as far as I remember. Be sure and get some new gaskets too before you bolt it all back up.
Old Dec 14, 2008 | 05:41 PM
Choreo's Avatar
Choreo
That is where mine was leaking.
Old Dec 15, 2008 | 04:06 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Thank you kind sir. It too has a warmed over LS motor in it.
Old Dec 15, 2008 | 04:10 PM
Eddie 70's Avatar
Eddie 70
Okay, I said I would add a few pics of my radiator leak checker. I made this a few years ago so I could pressure bleed my brakes on my 70. It worked real good for that so I thought I might be able to adapt it to the Z06 radiator. Here are a few pics of the bleeder and cap.
Old Dec 16, 2008 | 06:31 PM
rsiano@mac.com's Avatar
rsiano@mac.com
Default 180,000 when water pump was replaced
Hi,
My 1998 C5 daily driver in New Jersey had 180,000 miles on it when the water pump began to leak. Had my local mechanic replace it with a rebuilt one and the total cost was $500. Had to replace the starter at 178,000 miles and it cost me $500 including labor as well.
