remove headers for clutch install?
Old Dec 12, 2008 | 09:17 AM
Kurtomac's Avatar
Kurtomac
Default remove headers for clutch install?
i have LG pro's....do i have to remove the headers for a clutch install?
Old Dec 12, 2008 | 10:53 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Sure do PIA Ive had my clutch out 2 times in the past couple of months and pulling them is a pain, easy but adds more time to an already time consuming procedure.
Old Dec 12, 2008 | 11:20 AM
vettenuts's Avatar
vettenuts
I have QTP's and was able to work around them once they were unbolted from the heads. It was a pain though but I a least left them in the engine bay. Bigger issue was my FAST had to come off.
Old Dec 12, 2008 | 11:43 AM
ZZOOM06's Avatar
ZZOOM06
You can just unbolt the headers from the heads and let them hang loose, then you can move them around to get at the bolts that you need to remove to get the bottom cover off the bell housing. I've done it a bunch of times, really not that big of a deal.
Old Dec 12, 2008 | 12:43 PM
Kurtomac's Avatar
Kurtomac
damnit...didnt think of the FAST...so i suppose i gotta remove that too...might relocated my map sensor if i pull that off and extend that vacuum line going to the back of the intake
Old Dec 12, 2008 | 01:20 PM
slothy's Avatar
slothy
dumb question, but why does the fast have to be removed for a clutch?
Old Dec 12, 2008 | 01:29 PM
jedblanks's Avatar
jedblanks
probably because it hits the firewall when you tilt the drivetrain down to remove it.
Old Dec 12, 2008 | 01:30 PM
blue63cpe's Avatar
blue63cpe
Old Dec 12, 2008 | 01:31 PM
slothy's Avatar
slothy
makes sense, thanks
Old Dec 12, 2008 | 01:53 PM
Corvette Don's Avatar
Corvette Don
I unbolted mine and just moved them out of the way
Old Dec 12, 2008 | 02:02 PM
drivinhard's Avatar
drivinhard
yep just unbolt, and zip tie them to the side
Old Dec 12, 2008 | 03:23 PM
ZZOOM06's Avatar
ZZOOM06
You don't have to remove your FAST intake to do a clutch job,,,,total waste of time and effort. I DID NOT remove mine when I installed my TEX clutch.
Jimbo
Old Dec 12, 2008 | 03:45 PM
vettenuts's Avatar
vettenuts
Jimbo
As I lowered mine it was getting too close for comfort. Since it takes 10 minutes to remove, wasn't worth the risk to a custom ported FAST IMO.
Old Dec 12, 2008 | 04:21 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Yeah I'd definitely remove the FAST and I'd try loosening the headers enough and tie them to the sides
To remove headers for clutch install?
