Installing DeWitts With Left Side EOC?
Old Dec 15, 2008 | 01:45 PM
7LitreC5's Avatar
7LitreC5
Default Installing DeWitts With Left Side EOC?
I am installing the DeWits with a left side EOC. I bought the installation kit from DeWitts. Has anyone out there done this? If so I have some questions:
  • Did you use the straight or 45 degree pipe to AN adaptors on the radiator?
  • How did you route the oil lines. My ABS module is very close to the top EOC fitting.
Thanks.
Old Dec 16, 2008 | 07:10 AM
WKMCD's Avatar
WKMCD
I've got one sitting in the garage waiting for time to install.
Old Dec 16, 2008 | 07:59 AM
vettenuts's Avatar
vettenuts
I installed the radiator but not the lines yet. All I can say is while the radiator is out after the fan shroud is cut, practice installing the fans on the floor for a while before trying it in the car. Took me a while and it is a tight fit. Installation is clean and the radiator fits well though.
Old Dec 16, 2008 | 08:11 AM
7LitreC5's Avatar
7LitreC5
I put the fans and the radiator in as a unit and it went in pretty easily. It is only about 27 degrees out in the garage right now so it will be a few days before it is warm enough for me to get back at it.
Old Dec 16, 2008 | 10:38 AM
WKMCD's Avatar
WKMCD
I haven't looked yet. Is there enough room to install the cooler adapter without dropping the LT?
Old Dec 16, 2008 | 11:14 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
it's easier to install the fans from the bottom when the car is up in the air
I have zero experience w/ a LHS ECO, only RHS
I deal w/ Randy@DRM, great person to work w/, although they use Ron Davis, I find it more important to have the tech support
Old Dec 16, 2008 | 12:12 PM
7LitreC5's Avatar
7LitreC5
No there isn't. At least not with my SuperMaxx LTs.
Old Dec 16, 2008 | 01:48 PM
vettenuts's Avatar
vettenuts
Not sure on mine yet.
Old Dec 16, 2008 | 06:00 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I don't think it's a pipe thread in the rad for the cooler line's.Mine was straight AN.I'll post a pic this weekend on how I did mine.I have a 97 C5 so no abs module in the front to deal with.......................Paul
Old Dec 16, 2008 | 06:49 PM
7LitreC5's Avatar
7LitreC5
Pics would be great!
My rad has straight pipe to -10 AN adaptors screwed into the EOC. It also came with some 45 degree rotatable pipe to -10 AN adaptors.
I wish that ABS module wasn't in the way on mine. They should have left it where the 97s mount it...
Old Dec 17, 2008 | 04:48 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
I did not use Dewitt's installation kit so I can not give any direction on thier suggested routing, I bought my plumbing separeately from another supplier. For the lower EOC fitting I used a straight -10 AN connector, for the upper EOC fitting I used a relatively tight radius 90 degree -10 AN fitting and ran the hose down along the side of the radiator header until it cleared below the ABS module.
To Installing DeWitts With Left Side EOC?
