Leak from Washer Pump
Old Dec 16, 2008 | 08:46 PM
Rob 2K1's Avatar
Rob 2K1
Default Leak from Washer Pump
It appears that my washer fluid is leaking out of the weep hole on the bottom of the washer pump. I thought it was a bad seal between the pump and reservoir, but it just runs out from the small hole in the bottom of the pump. Has this happened to anyone else? Anyone have a washer pump sitting around?
-Rob
Old Dec 17, 2008 | 10:19 AM
HP_Addict's Avatar
HP_Addict
Do you mean water pump? If so once they leak they need to be replaced.
Old Dec 17, 2008 | 10:18 PM
Rob 2K1's Avatar
Rob 2K1
No, this is definitely the washer fluid pump. I fill up the reservoir and it runs right out in a small stream from the pump. I replaced the seal going into the reservoir, but the leak looks to be from the small hole in the bottom of the pump.
Old Dec 17, 2008 | 10:22 PM
lucky131969's Avatar
lucky131969
http://www.gmpartshouseusa.com/partl...layCatalogid=0
Old Dec 18, 2008 | 10:29 AM
HP_Addict's Avatar
HP_Addict
I would say replace the pump then. It should not be very expensive.
To Leak from Washer Pump
