Service ABS and Service Transaction Control error message
Old Dec 17, 2008 | 05:01 PM
ClearCoat's Avatar
ClearCoat
Default Service ABS and Service Transaction Control error message
I took my 99 C5 coupe vette to A & B imports in Plano, TX to get the brake pads replaced and fix the emergency brakes. After we picked up the car, I noticed that the car's dash showed the following error messages:
Service ABS
Service Traction Control
The ABS and Tranction control will then get disabled after the messages are displayed. I took my C5 to the dealership and they said I need the following new parts:
Brake Pressure Modulator Value $2200
Electronic Brake Control Module $620
The dealership also said the parts are located in the front of the car and could not of been damaged by the last auto shop.
Is there a cheaper way to fix this problem? I'd like to get my ABS and traction control working again.
Also, is there any way this could of been caused by the mechanics who changed the brakes?
Please help me if you can
-Clear Coat
Old Dec 18, 2008 | 10:19 AM
87SAM's Avatar
87SAM
First off you need to check the codes it's throwing.
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Dec 18, 2008 | 11:26 AM
chaase's Avatar
chaase
St. Jude Donor '12
I guess there is a chance that someone changing the brakes could have messed something up. The wheel speed sensors could have been damaged or a ground/connector came loose, but we would need the codes.
Old Dec 18, 2008 | 12:55 PM
trussme's Avatar
trussme
Default ..try this
and give us the codes:
with the key in the on position, but the engine not running
push and release the reset button until all messages cleared
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press "reset."
Now, during the "brake job" they may have disturbed a wheel sensors connection which would provide those warnings you got. Most likely it is NOT your BPMValve or EBCM...but the CODES you get will tell us...BTW,did the dealership actually run a diagnostic check (that they surely would have charged you $ for) to determine that those 2 components were defective??...there is...a cheaper fix if the EBCM is defective...SO, don't go back there until we get you a solution....
Old Dec 25, 2008 | 06:54 PM
ClearCoat's Avatar
ClearCoat
Default The DTC codes
Hi,
Here are the codes on my vette:
28-TCS
C1243 H: BPMV Pump Motor Stalled
40-BCM
B2723 H: PASS Key Detection Circuit
99-HVAC
B0367 H: Right Actuator Feedback Open
B0363 H C: Left Actuator Feedback Open
B0441 H C: Left Actuator Out of Range
A1-RDCM
U1064 H: Loss of Communications with BCM
B0-RFA
U1096 H: Loss of Communications with IPC
U1016 H: Loss of Communications with PCM
Is there anyway I can fix the problem without having to replace the BPMV or other major parts?
Thanks and have a Merry Christmas!
-Clearcoat
Old Dec 25, 2008 | 07:22 PM
Bill Dearborn's Avatar
Bill Dearborn
The motor is stalled due to a problem in the motor itself or insufficient voltage across the motor for it to turn. I don't have my Service Manual with me but one of the first things you can do is check the condition of the ground at G103 which is located along the drivers side front frame rail near the alternator. Also check the resistance between the BPMV case and G103, it should be zero. The BPMV is not cheap and once it is replaced the brakes have to be bled with a Tech 2 so the module can be cleared of air bubbles. A stalled motor may also be drawing a lot of current through the system relay in the EBCM which could lead to its failure as well.
Bill
Old Dec 26, 2008 | 10:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree with Bill Yes, there have been a few people that have solved this issue by servicing the grounds and making sure that all of the other body related electrical systems are normal, Battery properly charged, ALT output is NORMAL 14.0 -15.0 VDC.
Theres one other thing that has helped solve this issue on the CHEAP. Disconnect the connection for the BPMV Motor and apply 12VDC to the "MOTOR" side of the connector. (observe the CORRECT polarity) You can make the motor run for 10-15 sec which will free it up if its just stalling because it hasnt been used for a long time. Most people who have AH,ABS seldom activate the system.
Other than that, replacing it your self is the ONLY way to reduce the repair cost.
BC
Old Jan 5, 2009 | 06:45 PM
ClearCoat's Avatar
ClearCoat
To all the people who replied to this thread:
Thank you so much for your help so far. I really, really appreciate it. I must say that this problem with the TCM has gone away on its own. I no longer see the TCM error code when going into the manual diagnostic codes. Plus, I seem to no longer get the "Service ABS / Service Traction Control" error message when driving.
I am not much of a mechanic. Suppose this problem comes back in the future, which type of mechanic is best qualified to follow these instructions given to me on how to diagnosis my BPMW? Should I take it back to the dealership to follow the instructions from the replies to this thread or shoud I take it to a brake mechanic?
-Clearcoat
To Service ABS and Service Transaction Control error message
