Lube that stock shifter!
Old Dec 17, 2008 | 06:19 PM
The Wrench's Avatar
The Wrench
Default Lube that stock shifter!
After switching from GM syncromesh to Pennzoil Dexron III, and seeing a big difference in shifting feel; I of course wanted more, more, more.
So, I just decided to pop the 9-year-old shifter out and give it a good oiling. It felt pretty sticky, and I could see gummy lube on the sliding rod. Not sure what to use, I opted to try the GM super lube 12346241.
It sprays on thin and washes out all the old goo, but then dries to a light white PTFE grease.
I sprayed the heck out of the pivot point, lower bushing, and the slider rod, wiped off the drippings, and popped it back in and adjusted it.
Well, it worked! Another major step towards shifting Heaven.
After the lube set up overnight, it felt even better!
I know I'm gonna have to eventually get an aftermarket unit, but so far I'm happy with the positive results I've gotten. I'm sure there's some placebo effect here, but it truly feels like new now.
DG
Old Dec 17, 2008 | 10:27 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Very nice
So often people throw new parts at something when simple maintenance will go a long way to fixing problems
Old Dec 18, 2008 | 09:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep, lubing that shifter shaft and the ball does make a difference!
Old Dec 19, 2008 | 12:27 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I agree, maintenance goes a long way
Old Dec 19, 2008 | 08:46 AM
oakvillec5's Avatar
oakvillec5
preventative maintenance, that's the way to go !!
To Lube that stock shifter!
