Gears Question
Old Dec 20, 2008 | 03:13 PM
9secnotch's Avatar
9secnotch
Default Gears Question
Does anyonw know the rpm differnce between the 4.10 and 3.90 Gear for the 2003 z06?
Old Dec 20, 2008 | 03:58 PM
Patches's Avatar
Patches
It's a straight ratio calculation for different gear sets 4.10's are a 20% increase from 3.42's while 3.90's are a 14% increase.
Here are the FDR's for both the MN6 and M12 C5 tranny setups with different diff gearing.
In 4th gear (1:1) at, say, 3000 rpm with the 3.42's, the rear wheels (stock tires) will be turning at ~877 rpm. That would be reduced to 769 rpm with a 3.90 gear and 732 with a 4.10 gear. This translates to roughly 66mph with 3.42's, 58mh with 3.90's and 55mph with 4.10's. I calculated using 25.5" dia. tires.
Here's a table showing rpm's at varios speeds for different C5 trannies and diff gears.
Old Dec 20, 2008 | 04:31 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Now that's what I call a thorough answer
Old Dec 20, 2008 | 07:50 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Dec 20, 2008 | 08:33 PM
02gt350's Avatar
02gt350
only thing that is wrong there is 4th 5th and 6th gear in a coupe, and Z06 are the same.
Old Dec 20, 2008 | 09:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No, they're not.
4th is the same, that's it.
Old Dec 20, 2008 | 10:23 PM
9secnotch's Avatar
9secnotch
Hey patches thanks for the help..
Only thing is. i have a 4l60 in there and im trying to see if it will be feesable to run a 410 in there a jump up from my 3.90..
Old Dec 21, 2008 | 12:21 AM
Patches's Avatar
Patches
There are a few folks who've run an A4 with 4.10s. I've never driven one so can't say how it feels. Honestly can't imagine an A4 geared that low. The 3.42's I put in the wife's A4 are already aggressive for the highway.
Btw - why are you interested in 2003 Z06 gearing when you are planning for an A4?
Old Dec 21, 2008 | 08:23 AM
9secnotch's Avatar
9secnotch
planning for an A4?
the car is a 2003 z06 so i used it as a reference. it has an a4 in it with a 28" tall tire for the track. i was fishing around to see if i could pick up more going from a 3.90 to a 4.10
Old Dec 21, 2008 | 09:38 AM
Patches's Avatar
Patches
OK - then what you really need is the A4 version of the above FDR's. I recalculated using those:
This does not change the speeds I listed for the 1:1 scenario as all of them are equivalent at 1:1. The differences you'll see are in the lower tranny gears. The A4 spacing is much wider so I would expect a dramatic rpm swing between 1st and 2nd. The difference is less between 2nd and 3rd. I'd venture that choice of TC would be important with such low gearing. My MN6 with 4.10's revs quickly as I accelerate so I'd bet 1st gear in a 4.10 A4 would be very quick.
Old Aug 12, 2011 | 06:17 PM
had2have-it's Avatar
had2have-it
Subscribed
Old Jan 25, 2012 | 10:27 AM
Dennis Wilson's Avatar
Dennis Wilson
Originally Posted by Y2Kvert4me
No, they're not.
Old Jan 25, 2012 | 11:43 PM
don hall's Avatar
don hall
Is this any help?
http://mysite.verizon.net/foofoo2/c6/
To Gears Question
