Check Engine Light
Old Dec 24, 2008 | 06:05 PM
NEVERL8C5's Avatar
NEVERL8C5
Default Check Engine Light
My 99 coupe is coding P0171 and P0174 Fuel trim system lean Bank 1 and 2. I reset it and tightened the gas cap to make sure this was not the problem and it came back after a few miles. Reset again and drove it for 150 miles and it came back with only the P0171 code.Any ideas??
could a vacuum leak cause this?I think I have to fix the dreaded a/c vac line as the defrost lets air through during the a/c cycle.
Old Dec 24, 2008 | 06:22 PM
golfinz's Avatar
golfinz
Ive got the same codes, but I got them after I had my cam installed and tuned. In my case its probably in the LTFT, in yours, it could be a vacuum leak, post MAF. Check around the injectors, intake manifold, TB, or anything else that could become loose
Old Dec 25, 2008 | 11:09 AM
Bakersfield's Avatar
Bakersfield
When was the last time you replaced your fuel filter? I was getting lean codes on my work truck and a new fuel filter took care of that. Good luck and Merry Christmas!
Old Dec 26, 2008 | 10:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mr lead foot is having simular issues and it may be somewhat related to a POOR ground issue The O2 sensors are grounded at G-105/G-203.
If you have:
- Checked the intake ducting between the MAF and TB for 100% tightness!
- Check the ENTIRE PCV tubing and fittings for deterioration/damage (very common issue)
- Other vacuum leaks
Make sure that the Grounds for the O2 sensors are in good shape and tight!!
Hows those HIDs doing????
Bill Curlee
To Check Engine Light
