Need Help!!
Old Dec 25, 2008 | 08:59 PM
mickey_7106's Avatar
mickey_7106
Default Need Help!!
since tuesday ive been getting every possible message on the DIC. and all the lights in my gauges light up. it all started with my passenger window and door lock not functioning. i checked the codes and this is what i get:
10-PCM:
P1626H
28-TCS
U1301H
U1016H
40-BCM:
B0507H
B2587H
B2592H
U1255H
U1016H
U1096H
58-SDM:
U1301H
60-IPC:
U1255H
U1016H
U1040H
U1064H
U1176H
U1088H
80-RADIO:
NO COMM.
99-HVAC:
U1064H
U1096H
U1160H
U1255H
A0-LDCM:
U1255H
U1064H
U1016H
U1096H
A1-RDCM:
NO COMM.
A6-SCM:
U1300H
U1255H
U1016H
U1064H
B0-RFA:
U1255H
U1096H
U1064H
U1016H
C2110H
when i clear the codes everything is ok. but if go on a bumpy road all the lights on my gauges start lighting up. i get that REDUCED ENGINE POWER and a lot more messages. both my doors wont work. and when i check for codes at that point they all read NO COMM.
ive checked most of my grounds and theyre all clean. and if i shut the passenger door hard enough the locks and windows start working for just a little bit
anybody else had a similar problem?
what was the solution?
sorry for the long post, bad grammar and misspelling
Old Dec 25, 2008 | 09:08 PM
lar66BB's Avatar
lar66BB
Default codes
Check the computer connections on the one behind the passenger
foot floor board, you may have a loose connection feeding the computer
module.
Old Dec 25, 2008 | 09:10 PM
mickey_7106
module.
the one next to the fuse box? if so i even removed it to inspect it but it looked good
Old Dec 25, 2008 | 09:11 PM
z06 hellcat's Avatar
z06 hellcat
check and clean all of your ground's!
Old Dec 25, 2008 | 09:13 PM
mickey_7106
one thing i forgot to mention is that when im deleting the codes i hear like a small motor running inside the dash and the brake pedal depressurizes
Old Dec 25, 2008 | 09:14 PM
mickey_7106
its still IP..but this rain wont let me
Old Dec 25, 2008 | 09:16 PM
lar66BB's Avatar
lar66BB
No there is one inside of thecar on the passenger side. It is under the dash. You will see two tabs that you pull done and
then you can remove the cover.
It is on the slanted part of the floor.
And it is a good idea to check all the ground wires. I think there are four
connecting to the frame. front and back. But I'm not sure about that.
Old Dec 25, 2008 | 09:20 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'll refer to Bill Curlee's many posts on the accordian tube in the door jam where there is a known wire that can and will short to the frame causing your issues. Check both door jam tubes.
Old Dec 26, 2008 | 12:27 AM
Bell's Avatar
Bell
Take your car to AutoZone and have them test the battery and generator. They'll hook up a test rig to your battery in about 10 seconds and they do it for free. With all the U codes your getting (loss of communication between computer modules - usually happens when voltages get too low), either the IPC is toast (exceedingly rare) or your battery is going bad (common as dirt) even if it doesn't sound like it. Most likely you just need a new battery.
Old Dec 27, 2008 | 04:47 PM
mickey_7106
i took my battery to autozone to get it tested and it turned out good. so far i've checked grounds: G201, G103, G101, G102, G104, G202 and G401. and it still trows codes.. i did noticed that G402 was not there(behind the passenger RW). the stud where it should be had some kind of rubber boot on it. not sure if thats normal for a 2000
Old Dec 27, 2008 | 04:48 PM
mickey_7106
i will do that next
Old Dec 29, 2008 | 10:08 AM
mickey_7106
got her all fixed..it turned out it was a wire shorting out in my passenger accordian tube..
thanx to all for your input
Old Dec 29, 2008 | 10:12 AM
ecoman's Avatar
ecoman
Bill,s the man for problems glad your all set
Old Dec 29, 2008 | 10:52 AM
j84buick's Avatar
j84buick
Link to the fix? I tried searching for accordian tube but no luck.
Old Dec 29, 2008 | 05:28 PM
timemender's Avatar
timemender
Sticky at the top of the C5 Tech section - IMPORTANT ELECTRICAL INFORMATION (Long!) (electrical issues)
Old Dec 30, 2008 | 01:42 PM
mickey_7106
http://forums.corvetteforum.com/1563500141-post12.html
http://forums.corvetteforum.com/1567604471-post2.html
To Need Help!!
