engine removal
Old Dec 29, 2008 | 07:51 PM
hermancar's Avatar
hermancar
Default engine removal
First of all i am new to the sight. Is there any otherway of removing the engine and trans(auto) without removing the complete body. thanks
Old Dec 29, 2008 | 08:05 PM
dougbfresh's Avatar
dougbfresh
Sure, out the bottom.
Old Dec 29, 2008 | 08:43 PM
squidwards vert's Avatar
squidwards vert
Trans, diff and TT out the bottom, engine from the top not too difficult. Cajundude has a good write up. Just took the entire drive line out myself last weekend.
You will need
A very good heavy duty hydraulic lift, rent or buy
Excellent set of tools, 3/8 and 1/2 with multiple types of ratchets, extensions and breaker bars and be prepared to purchase a few more along the way
Air compressor and air ratchet
Several specialty tools to deal with the balancer on the front of the engine and the hydraulic quick disconnect
Four jack stands, six are better though
One low profile jack, one heavy duty three ton jack, a bottle jack, transmission jack and a regualr 19.99 jack
At least 8 (2 per jacking point) 1'x1' brick pavers + 2 extra per side to stand on while working in the engine bay
Two boxes of zip lock baggies and marker to label every single bolt you remove.
digital camera to take pics, you will forget where everything is located and how they go back together.
Copies of several different write-ups from the experts on here including Dope and Cajundude.
That should get you started. This is my third time going this route and I actually enjoyed the process this time around. Learned many tricks and short cuts.
PM me if you need any help
Best of luck if you decide to go this route. Sorry if my reply was more then you were looking for, just wanted to give you an idea what you are up against. But it is very satisfying to do it yourself.
the squidman
Old Dec 29, 2008 | 08:49 PM
Brandon619's Avatar
Brandon619
When I did my motor swap from the top I did not remove the drivetrain at all. It is not to bad doing it from the top but a extra person to help is a must.
Old Dec 30, 2008 | 12:20 PM
hermancar's Avatar
hermancar
No such thing as too much info thanks.
Old Dec 30, 2008 | 02:39 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you want to drop the drive train and engine at the same time the only way to do it is from the bottom. It's really not that bad to do.
When my brother and I dropped my drive train and pulled the engine, we did it in 2 steps. Drive train from the bottom and engine from the top. Worked pretty well.
Old Dec 30, 2008 | 11:14 PM
lp2k's Avatar
lp2k
the squidman
I was going to suggest seeing that guy or searching for his postings online
To engine removal
