cruise controll problem c5
Old Dec 29, 2008 | 11:31 PM
tonycorvettes's Avatar
tonycorvettes
Default cruise controll problem c5
2001 cvt ,i have looked ,dont see any threads to help me,ill be drivng down the road after about 20 miles on cruise and it will disengage,ill just press the criuse button and it works again, and does it again,,any advise..thanks
Old Dec 29, 2008 | 11:38 PM
Bill Dearborn's Avatar
Bill Dearborn
Do you see any messages on the DIC like Active Handling or Traction Control on? Activation of either will cause the cruise to stop. You could also check the clutch (if you have one) and brake pedal switchs for proper operation and adjustment.
Bill
Old Dec 29, 2008 | 11:44 PM
tonycorvettes
Default hey bill,,,
i wanted to thank you and mike for helping me on my ebcm broblem,,turns out i had two of these outfits work on and return my module saying its good,,they were not,absfixers finally sent me another one and that fixed it,,,,,now this criuse controll thing is as i said but no indication on the dash,now i didnt look for anytrouble codes because i didnt get any thing on the dash
Old Dec 30, 2008 | 02:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some EBTCM have a defective microprocessor and the EBTCM applies the brakes in a modulated application when the car is driving straight down the road. My 02 ZO6 EBTCM had that issue along with erroring out at 42 MPH.
Do you feel any braking just before the cruise trips off?
Also check your brake peddle switches to make sure that there not causing the Cruise to trip off.
BC
Old Dec 31, 2008 | 04:51 PM
tonycorvettes
Default Codes
i just pulled the codes,ill clear them abnd drive it home and see what comes back,, p1431 u 1255 b2606 b2860 u 1000
Old Jan 1, 2009 | 12:25 AM
redazz's Avatar
redazz
Bill
i agree with bill check the clutch pedal and brake pedal switches i had a similar problem and it was a simple adjustment on the clutch pedal switch.
john
Old Jan 1, 2009 | 01:11 AM
tonycorvettes
Default ok
ill check the pedal switch,it does seem quite sensative
Old Jan 1, 2009 | 04:03 PM
mike348's Avatar
mike348
Mine was kicking out for a year till it threw a steering wheel position fault. Changed out and all is good.
To cruise controll problem c5
