Brakes Upgrade Advice
Old Dec 31, 2008 | 03:49 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Default Brakes Upgrade Advice
I’m in need of putting new calipers and Rotors on the C5 and I need some advice on just what to purchase. GM has their slotted and drilled rotors for the C5 that run $389. Then there is the Baer Decela rotors for $599 and the Baer EradiSpeed for $775. My question is are the GM rotors any good? I know that with the EradiSpeed I get a life time warranty against warping and 3 years on the Decela. I want to Road race out at Grand Sport Speedway Groove Union this spring.
With the GM rotors I can save some major $ but will they stand up to the track time.
Old Dec 31, 2008 | 04:33 PM
geerookie's Avatar
geerookie
For track stuff plain rotors are the best. No slots or drilled.
This has been discussed many times over in Autocross and Road Race section. Do a search and you will find tons of info.
Old Dec 31, 2008 | 06:21 PM
Oldvetter's Avatar
Oldvetter
Use NAPA Solid rotors for track use. Paint edges, vents, and top hats with high heat rusteleom. Pads your choice, I like Hawk HPS.
Old Dec 31, 2008 | 07:26 PM
Burnt C6's Avatar
Burnt C6
Cruise-In X Veteran
Thanks Guys I didn't even know there was that section. I'll go and do a search.
Old Dec 31, 2008 | 07:51 PM
Dave Sweatt's Avatar
Dave Sweatt
Probably a crud load here as well, 'specially lately.
To Brakes Upgrade Advice
