Headlights wont work ??????
Old Jan 2, 2009 | 06:40 PM
rover37's Avatar
rover37
Default Headlights wont work ??????
I bought a C5 and the battery was shot, So i assumned it was the battery. When I jumped the car and had a charger on they went up and down....ONCE.
I took it to Chevrolet and they tell me its the Multi Function switch. My fogs work. Well Chevy wants $800.00 which is insane. Does this sound like the problem? I can buy the swithc aftermarket for $188.00 and instal it myself.
Old Jan 4, 2009 | 10:13 PM
1999vettguy's Avatar
1999vettguy
I had a battery that was going bad. Could charge it and they would work once the charge started to diminish the headlights would not pop up. Batteries go quickly on these cars. I would first make sure the battery is good/new then see what happens after that.
Old Jan 4, 2009 | 11:27 PM
T.J.'s Avatar
T.J.
If your battery is to low your lights will not work. Buy a new battery first.
Old Jan 5, 2009 | 10:06 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree on insuring the battery is up too full power first. If you get to that point and they still don't work, then the headlamp switch can be replaced. Its easy to do yourself and you don't need to remove the steering wheel to do it.
Old Jan 5, 2009 | 10:10 AM
knyght4's Avatar
knyght4
I guess that goes to show you how much the auto industry is hurtin. That's a little much for a small fix.
To Headlights wont work ??????
