Themostat
Old Jan 7, 2009 | 04:30 PM
guitar420911's Avatar
guitar420911
Default Themostat
I'm looking to flush my radiator and I figured I would also replace the thermostat.
Who makes the best thermostat for the price?
Old Jan 7, 2009 | 06:35 PM
vettenuts's Avatar
vettenuts
GM.
Is there a problem with the one you have? If not, I would just leave it.
Old Jan 7, 2009 | 07:41 PM
dougbfresh's Avatar
dougbfresh
A failsafe thermostat if your going to replace it. Most stats fail closed, you want one that fails OPEN in the event of problems.
Old Jan 7, 2009 | 08:06 PM
guitar420911
I'm looking to upgrade it to a 160 or 180 degree.
Old Jan 7, 2009 | 08:37 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I have used SLP and hypertech. Is yours just the stat or does it require the housing with the stat? I have a new 160 SLP stat that a friend never did pay for but it's just the thermostat. I know 2000 has the stat and housing togethor but I don't know about the 01 and up.
Old Jan 8, 2009 | 02:54 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
You can also add a shim to your factory thermostat, and make it start to open 10-15 degrees sooner.
Old Jan 8, 2009 | 05:57 PM
vettenuts's Avatar
vettenuts
Link to thermostat mod
As a follow-up to that link, I ended up putting in the shortest shim that I tested. In cold weather the motor runs at around 178 degrees (maybe down to 176 coasting down a hill). I think it will run in the low 180's in warmer weather.
Old Jan 9, 2009 | 08:14 AM
Quicksilver Vert 01
Originally Posted by vettenuts
As a follow-up to that link, I ended up putting in the shortest shim I think it will run in the low 180's in warmer weather.
I did the same thing as you. In late November, I was seeing coolant temps. in the mid 170's, with a .100 shim in my factory thermostat. I reduced the shim thickness to .050, to bring the temp. up about 5 degrees.
I've found that the stove top method of testing will get you in the ball park, but it takes some actual driving to determine the end result of the added shim.
I haven't road tested yet with the .050 shim, but I think it's going to be just about right.
To Themostat
