Replacing Harmonic balancer on 2001
I have used a couple of different ways to HOLD the damper while removing or installing the bolt. The best way is to purchase a heavy duty strap wrench. It seems to work the best.
Purchase a LONG breaker bar, your going to need it!
Autozone rents the 0-250 ft/lb torque wrench that your going to need if you use the ARP bolt.
I used an ARP Damper bolt instead of the stock GM bolt and I purchased an aftermarket damper. I used a POWERBOND Damper and it works great! Excellent quality for the price.
Heat the damper hub before you use a 3 Jaw Puller to remove it. I used a wagner heat gun and / or a propane torch. Most people feel safer using a heat gun. You only need to get the hub up to about 150-200 degrees to help it come off easier. It makes damper removal a LOT easier.
REPLACE THE TIMING COVER DAMPER SEAL! Use a new GM seal. While your there, I strongly recommend replacing the stock timing chain with a LS2 chain. Its a direct fit and a LOT more dependable. The new LS2 chain is installed. Im holding the old chain.
When you reinstall the damper, again, heat the hub and make sure that you rent, borrow or purchase a tool thats made to reinstall the damper. If you use the old bolt to start to press on the damper, you run a chance of damaging the crank snout threads. They will strip out. Vettenuts has a really good designed tool that he made. I copied his tool and it works excellent. I cut the head off the old stock bolt and welded on some all thread to the back of the stock bolt.
MAKE SURE that you use a NEW BOLT or an ARP bolt when you reinstall the damper and use correct torquing sequence for which ever bolt that you choose.
If you have questions, please let us know.
Bill
I know its a while your at it thing,,,,,,,but should the timing chain be replaced on a motor w/76k on it?
I purchased an SLP HB lower pulley. The instructions
Requires a New Serpentine Belt Dayco P/N 5060780. I would rather use Gatorback. Anyone know which GB is the same as the Dayco?
I have two belts last #' are 798 & 795.
Last should I get a front end alignment after I replace the steering unit?
