Engineering Project, need C5 3D model!
Old Jan 11, 2009 | 07:24 PM
agoodride's Avatar
agoodride
Default Engineering Project, need C5 3D model!
Hello everyone. For my mechanical Engineering project I wanted to design my own lambo style door hinges for a C5. In order to do this I want an accurate model of the fender, door, door post, and window pillar. I will be using Pro/Engineer for CAD and CAM.
Does anybody know where I can get some geometry information on these components? Also I would need to center of gravity of the door as well.
Any help would be appreciated! Thanks in advance!
Old Jan 11, 2009 | 08:27 PM
Choreo's Avatar
Choreo
I have never seen one of a C5. That is on my list of projects for this year - to do a fully detailed 3D version of the C5 in Carrera, but that is weeks away.
Old Jan 11, 2009 | 08:43 PM
Dave68's Avatar
Dave68
There's a website that has the C5R in 3D Studio max format:
http://car.3dsmax-stuff.com/2008/10/...-3d-model.html
And here's one that charges $70 for a C5 in the same format:
https://www.the3dstudio.com/product_...earch=Corvette
Does Pro-E import 3ds files?
Old Jan 11, 2009 | 08:55 PM
agoodride's Avatar
agoodride
I'm not sure. I'll have to look into that tomorrow at school. looks like the 3ds files are used in games and if I'm right they probably don't have the geometry perfectly accurate. Thanks
Old Jan 11, 2009 | 08:57 PM
agoodride's Avatar
agoodride
weeks? I would have guessed months or years. good luck with your project! I'll be curious to see how it turns out!
Old Jan 11, 2009 | 09:05 PM
lucky131969's Avatar
lucky131969
I'll PM you my number.
Old Jan 11, 2009 | 09:09 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
No, Pro/E does not.
It may be possible to export the file into a DXF or step that would import into Pro. However, experience tells me that you usually get wireframe rather than a solid.
Old Jan 11, 2009 | 09:11 PM
nj02vette's Avatar
nj02vette
I've never seen any readily available file that would import into Pro/E. Perhaps you could contact GM directly and tell them that you are a student.
GM uses Unigraphics , but those models can be imported directly into Pro/E (not student version).
Old Jan 11, 2009 | 09:18 PM
agoodride's Avatar
agoodride
I've been considering contacting GM, but not really sure where to call to get 3d models though. I'll have to look into this more as well. Thanks for your input!
Old Jan 11, 2009 | 11:46 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
man... its been a few yrs since i have done Pro-E...i changed over to Solidworks, so much easier to use.... good luck with modeling though, i've always wanted to take on that challenge, but DAMN, it would be a lot of work!
Aj
Old Jan 12, 2009 | 12:01 AM
Dave68's Avatar
Dave68
Aj
I went from Autocad 2D to Autocad 3D to Designer (Autodesk's 1st attempt at a real 3D program) to IronCAD to SolidWorks, and back to IronCAD as my preferred program. IC is a a much better conceptual modeling tool if you are building an assembly from scratch. I still use SW at work and it has some really nice capabilities. However if you've ever used the IC TriBall, you are spoiled for life.
Pro-E IS very powerful, as is Catia and Unigraphics. The learning curve for the mid-range modelers is somewhat shorter from what I understand. If you are a 1-person company and money is tight, Alibre is 90% of the $5000 programs for less than 1/3 the cost.
Can you tell I've been doing this for a lonf time? I just wish I could remember everything........
By the way, I believe Patches used Pro-E Wildfire; maybe he has run across a 3D C5.
Old Jan 12, 2009 | 12:08 AM
Choreo's Avatar
Choreo
Since I am all Mac-Based the past 18 years, I will probably be modeling in Amapi Pro and then exporting to Carrera for rendering.
Of Course, the new Intel Macs like mine can also run PC programs, but I have never used that feature.
I kind of doubt you are going to get a very detailed model commercially in the $70 range.
Old Jan 12, 2009 | 12:57 AM
barack's Avatar
barack
1st Gear
Researchers at the University of Alberta study the complex interactions between charged particles and the magnetic fields that extend far into the upper atmosphere of many planets. Most of these charged particles are expelled by the sun in the form of solar winds, and interplanetary coronal mass ejections. This interaction is often visible from the Earth's surface in the form of the Auroras - the Northern and Southern Lights.
and for more reference I think you must go for an online help Car TouchUP .
Old Jan 12, 2009 | 07:15 AM
vsocks1's Avatar
vsocks1
What??
Old Jan 12, 2009 | 09:08 AM
slothy's Avatar
slothy
haha?
Old Jan 13, 2009 | 11:14 AM
agoodride's Avatar
agoodride
Old Jan 13, 2009 | 09:29 PM
Patches's Avatar
Patches
I currently use SW at work and we recently installed a couple of Pro E Wildfire 4 seats for compatibility with one of our clients. I haven't used Pro E for three years since moving to my present job and honestly don't miss it at all. I maintain my own AutoCAD license and have done some pretty complex models in that - yes, standard ACAD. Those familiar with it cannot believe the 3D models I've done but I'm self-taught and started in 3D in ACAD because I didn't know any better. Been doing it for 15 years. SW has me spoiled though.
Here's the only 3D model of the C5 I have found to date.
http://www.turbosquid.com/FullPrevie.../257570/blFP/1
$120 and only in the following formats.
  • 3ds Max 3.00 ( .max )
  • 3D Studio ( .3ds )
  • Cinema 4D ( .c4d )
  • Lightwave 6.00 ( .lwo, .lw, .lws )
  • Softimage ( .hrc, .xsi )
They also have a C6, a Ferrari F50, a Ferrari 575M Maranello and several other cars.
To Engineering Project, need C5 3D model!
Old Jan 13, 2009 | 10:00 PM
agoodride's Avatar
agoodride
I've talked to others about using these types of files and the likely hood of getting anything useful into Pro/E isn't very good. It seems that are basically useful in 3d games and not very good when it comes to technical drawings. Thanks for the info though. I'm still looking into my options. I want to contact GM and see what they will give me if anything. Anybody know who to contact?
Old Jan 17, 2009 | 01:16 PM
nj02vette's Avatar
nj02vette
Aj
Solidworks is great........until you have to deal with more than 50 parts in an assembly. It's a great modeler, but not worth a damn for complex assemblies.
Can't believe you'd prefer Solidworks over Wildfire. While Pro/E definately has some quirks and is slighly more difficult to use, they just aren't on the same level when you get to complex assemblies.
Old Jan 17, 2009 | 02:53 PM
Patches's Avatar
Patches
Didn't say I prefer SW over WF. I said I prefer it over the older Pro E that I used at my previous job. I used pre-WF Pro E there and switched to SW when I took a new job. I mentioned that we recently installed WF 4.0 because we have a new client that uses Pro E so had to for compatibilty reasons. I don't have enough seat time in WF yet to have an objective opinion but, regardless of what I personally prefer, I have to use what my company uses because that's what the workstations have installed and it's what 99% of our clients use. They comprise the biggest corporations in the medical industry so I guess SW has a pretty large fan base in my industry.
