Is this the low battery problem??
Old Jan 12, 2009 | 08:57 PM
Ontheroad's Avatar
Ontheroad
Default Is this the low battery problem??
When I crank my vette, after it's been sitting overnight, just about every warning light comes on and stays on, then they eventually go out (after maybe a minute). Then traction light will stay on along with the security light. The display tells me to service the traction system and the tire pressure system. This will stay on till I turn the car off and crank it again. Then everything is back to normal.
One time everything on the dash died while driving down the road (gauges, lights, everything), only to come back on a minute later.
I have read here that a low or aging battery can cause these kinds of episodes, so what do you think? I have purchased a battery tender, and I intend to try it out tonight to see if it helps. Thanks for any input.
--DAN
Old Jan 12, 2009 | 09:14 PM
aleadfoot's Avatar
aleadfoot
Could be loose connections or bad ground but I'd check the battery. Usually intuition is correct
Old Jan 12, 2009 | 11:48 PM
Corvette-Dan's Avatar
Corvette-Dan
Default battery
If the battery is even just a few years old I would start with that. Cured my electrical nightmares.
Old Jan 13, 2009 | 07:44 AM
Bugaboo's Avatar
Bugaboo
What you may want to do is have the dic set to observe the voltage when you crank.
Old Jan 13, 2009 | 07:49 AM
1badf350's Avatar
1badf350
I'm currently experiencing this too. I replaced the battery last week and still have the problem. That said, my driver door switches started acting up before all this started. Now the door switches won't operate at all and I still get all the warning lights and the radio goes out.
I'm gonna try to pull the door panel off to check the connections once the weather warms up a bit.
Old Jan 13, 2009 | 08:01 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
If the battery voltage is low, the displayed infornation on the DIC may not be accurate.
Measure your cranking voltage right at the battery terminals with a volt meter. Also check your battery cable connections at both ends. Make sure the positive cable is tightly connected at the starter.
You could also have the battery load tested at most auto parts stores.
Old Jan 13, 2009 | 03:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
--DAN
Dan
Read and post your DTCs The BCM controls all that stuff through the IPC. If the BCM is wet or damp or has been wet or damp, it will cause some really weird issues. You could also have a serial data buss issue.
Grab the rubber accordion tube that runs between the door and door frame. Feel for the two wiring harnesses in the tube. Grip the harness's inside the tube and shake the heck out of them and see if conditions change. If they do, we can fix the issue.
BC
Bill
Old Jan 14, 2009 | 10:30 PM
Ontheroad's Avatar
Ontheroad
Well, in case anyone wants to know, got the car back from the Chevy dealer, and they have one guy who works on all the Vettes.
Here is a list of things fixed:
1. Looks like whoever had the car before me had a new BCM installed but never had it programmed properly. Now my telescopic wheel, power seats, etc work perfect. I didn't even know the seat was supposed to roll back when you turned the car off, but now it does! The headlights even come on automatically at night. Didn't do that before.
2. He cleaned some corrosion off the battery terminals and around the underside of the battery. After hearing some of your posts, definitely wanted to do that.
3. Replaced the center console.
4. Had the transmission fluid flushed and replaced (64,000 miles).
5. He noticed the controls on the drivers door not working right, so he pulled the door panel off and found the male/female connectors in bad shape. Was able to splice and replace those. Now memory seats work. Just thought I didn't know how to set 'em...
Haven't seen the lights on the dash stay on, so hopefully that problem is solved! So for a newbie, I feel a lot better about my purchase, but somewhat baffled how someone would not keep up the maintenance on such a fine car.
The last thing is.... gotta get a new brake fluid reservoir. This one has a slight leak around the seam. THEN maybe I can get some performance mods going!!
Thanks for listening.
--DAN
To Is this the low battery problem??
