C6 performance from a c5
Old Jan 15, 2009 | 12:45 PM
M_T_0's Avatar
M_T_0
Originally Posted by sikpuppy
Current pricing from LPE is below. Just a little off on your stated price. If you want 500BHP, you have to start with a LS6 engine first
430 BHP / 400 lbs-ft of torque
Package includes:
Engine removal, inspection and disassemblyLingenfelter CNC porting & polishing of LS1 cylinder heads Competition Cams valve springs
2.02" / 1.57" Stainless steel intake/exhaust valves Three angle valve job, set correct spring tensions & heights Port matched LS1 intake manifold Ported and polished throttle body Lingenfelter designed Competion Cams hydraulic roller camshaft Modified oil pump assembly 160 degree thermostat Professional installation, testing and pcm tuning All necessary gaskets, fluids & bolts Corsa stainless steel exhaust 4 - tip touring system Blackwing washable air inlet system Chassis dyno testing after installation
Lingenfelter 3 year / 36,000 mile warranty
Excellent drivability, highway mileage not adversely affected Lingenfelter certificate of authenticity
1997-2004 Package Price $8,995.00
View chassis dyno test
Required additions
1999 - 2000 fuel injectors $200.00
1997 - 2000 ZO6 intake manifold $600.00
*Includes automatic transmission shift improvements. Some applications may benefit from a higher stall torque converter. Please ask your salesperson for details and prices.
Normal installation time required: 2 weeks with prior notification.
Items on this page are not legal for sale or use on California pollution controlled motor vehicles unless they are listed with an E.O. number.
21st centry is our local lpe dealer and there qoute is as follows
: products - online store
: installed engine
packages
: videos
: dyno testing / tuning
: contact us
: cars for sale
: site map
: authorized installer
21st Century Muscle Cars 500 BHP Heads & Cam Package
2001 - 2003 Corvette ZO6
5.7 L Engine package
500 BHP / 460 lbs-ft of torque
Package includes:
• Engine removal, cleaning, inspection and disassembly
• Professional degreeing of camshaft
• Lingenfelter Stage 2 LS6 cylinder heads
• LPE valve springs and lightweight valve spring retainers
• Over sized stainless steel intake/exhaust valves
• Three angle valve job, set correct spring tensions & heights
• Custom Competition Cams hydraulic roller camshaft
• Oil pump modification
• Ported and polished throttle body
• MSD 8.5 MM spark plug wires
• NGK TR55 spark plugs
• Stainless long tube exhaust headers
• High flow catalytic converters and Y pipe
• Rollmaster timing chain set
• All necessary gaskets, bolts and fluids
• Professional installation, testing and LS1 Edit tuning
• 1 year warranty on parts and labor
2001 - 2003 Corvette package price $6,495.00
Old Jan 15, 2009 | 08:16 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Originally Posted by Chevy-SS
Ouchie, $9,000 is a boatload of money for those few mods. I would do a SC way before this.
Supercharging (done right) will cost a lot more or a little less (depending on the supercharger and whether you are going to do the install yourself).
Old Jan 15, 2009 | 08:18 PM
Chemdawg99's Avatar
Chemdawg99
: installed engine
packages
: videos
: contact us
: cars for sale
: site map
Package includes:
I am aware of this package (I'm from Fort Worth, TX, BTW) and John Page does excellent work. well worth the money
Old Jan 15, 2009 | 08:32 PM
Chevy-SS's Avatar
Chevy-SS
Check this thread:
http://forums.corvetteforum.com/c5-f...installed.html
I don't see how anyone can possibly beat that kind of a deal. I have never installed a SC on a Vette, and I don't really care to experiment on my car. I'd rather have someone do it who has done it before, and can tune it right there.
I have auto trans, so I might have them do something to the trans, not sure. I have 3.15 gears, so I'd consider switching to 3.42's.
Anyway, for less than $7,000 you've got a SC on your car and you're definitely making good power........................ Plus, you haven't ruined drivability, which is very important to me. I've been driving high-power muscle cars for 35 years, and they are fun, but I'm tired of rumpety-rump cams and rough engines.
Old Jan 16, 2009 | 03:38 PM
kendo347's Avatar
kendo347
Check this thread:
Skip all of the mumbo jumbo and go straight to the sc. I have all the bolt ons and spent the same amount in total to have a sc. If money is an issue save it. Air filter here, headers there. NO!!! Get a s.c. then start doing the little bolt ons.
Old Jan 16, 2009 | 10:23 PM
Bell's Avatar
Bell
To the OP, hopefully you realize that ALL the hp numbers you see from GM (or any other manufacturer) are flywheel numbers, not rear wheel horsepower (rwhp).
My 2002 Coupe was 296 rwhp, even with a Blackwing CAI and Ti Z06 catback.
A&A V3 SQ s/c added 143 rwhp (439 rwhp) and cost about $5,000. And that's with a restrictor plate in the intake to keep it under 9 psi boost!!! I installed it myself (had never installed one before - Andy will walk you through it over the phone bolt by bolt if necessary). Normal street driveability around town, but push the pedal down and hang on.
Old Jan 16, 2009 | 10:48 PM
motogib1's Avatar
motogib1
You really don't need that much to run with a stock LS3. Instead of looking a hp, look at 1/4 mile ET. Road track performance is something else altogether. I would guess that headers, vararam, 3.42 or 3.73 gears and a high stall with tuning would allow you to run with the LS3. The quick LS3s appear to run low 12s based on a glance at the C6 performance list. There are a couple of outliers below that but generally they run 12.25 to 12.6 at around 114 or 115 mph. I am at 12.33 @ 114 mph, check my signature for mods.
Old Jan 17, 2009 | 08:36 AM
AU N EGL's Avatar
AU N EGL
LS2 or LS3 create motor
Both will need the LS1 adapter kit and the LS3 will need a bigger radiator. LS3 and all larger cube motors run hot.
