Will A/C come on when...
Old Jan 16, 2009 | 07:43 AM
dcd58's Avatar
dcd58
Default Will A/C come on when...
...it's 20 deg. or less outside?
Hi all!
Had to bring my car in last week. Starter died all is well on that now but I noticed that when I took my car home yesterday (from stealership!) I put on the defroster and I noticed the A/C light did not go on. It was below 20 outside. I know that the A/c does not come on below a certain temp, but I thought the defroster always put on the compressor and thus the light for the A/c came on
Don
Old Jan 16, 2009 | 07:47 AM
dougbfresh's Avatar
dougbfresh
No, I don't believe it will.
Old Jan 16, 2009 | 07:50 AM
dcd58's Avatar
dcd58
Thanks, I never took the car out in that type of weather but I had to get it home..was there for over a week! Just don't want a problem come summertime..I know it worked before bringing it in!
Old Jan 16, 2009 | 10:40 AM
Oldvetter's Avatar
Oldvetter
No it won't, lowest outside temperature is something like 35 or 38 F, when it turns off.
Old Jan 16, 2009 | 12:33 PM
spdracr39's Avatar
spdracr39
Yep the manual says the compressor won't run below 40 degrees F outside air temp.
Old Jan 17, 2009 | 08:22 AM
dcd58's Avatar
dcd58
Thanks everyone! I guess I was wrong, I could of swore I saw the a/c light come on if I put on the defroster
Old Jan 17, 2009 | 12:20 PM
DeeGee's Avatar
DeeGee
I know none of us ever reads the manual but it's got a good description for this one:
A/C (Air Conditioning): This button turns
the air conditioning compressor off or on under most
conditions. The light on the A/C button will come on
when the compressor is operating in either the automatic
or manual mode. The air conditioning does not operate
at temperatures below approximately 35F to 40F
(2C to 4C). The light on the A/C button will flash if
pressed when air conditioning is not available. The air
conditioning cools and dehumidifies the air coming into
the vehicle. The air conditioning cannot be turned off in
defrost and defog, as it helps to remove moisture from
the vehicle. It also helps to keep the windows clear.
To Will A/C come on when...
