Running coupe without TPM
Old Jan 20, 2009 | 09:56 AM
Hall1836's Avatar
Hall1836
Default Running coupe without TPM
What happens if I run tires and wheels without Tire Pressure Monitors(TPM). Some say you have to reset everytime you start the car, but won't you get the "chimes" as you drive. Can you temporaily disable and put the sensors in at a later time. Thinking of buying tires and wheels already mounted, want to run them out about 5000 miles before replacing tires. Thanks
Old Jan 20, 2009 | 10:06 AM
87SAM's Avatar
87SAM
It appears you have a 2001 and if that is the case, it can be programed out. Or you can just hit the reset button when it first chimes and you will be good till the next start up.
Old Jan 20, 2009 | 10:08 AM
bluvette79's Avatar
bluvette79
transfer the ones on your existing wheels?
Old Jan 20, 2009 | 11:34 AM
Hall1836's Avatar
Hall1836
No can't change them out, will go new when time comes. If I do the deal will sell the Z16 polished rims with mounted run flats with tire pressure sensors.
Old Jan 20, 2009 | 01:15 PM
iced98lx's Avatar
iced98lx
Hit reset everytime or, clear the codes once every xxx miles.. It takes a while for them to pop back up (it has to loose communication with them for a while before it dings at you).
To Running coupe without TPM
