Need help with codes please
Old Jan 20, 2009 | 04:15 PM
01corvettec5's Avatar
01corvettec5
4th Gear
Default Need help with codes please
Hello everyone. I pulled these codes earlier and also got reduce engine power, service traction control and service abs. Also my windows dont work and door locks. I know h stands for history and c is for current. I can also look the codes up just need to know how to try to fix them. also my battery dies super fast. Brand new battery.
codes
10pcm p1518 h c
28-tcs c1236 h
28-tcs c1278 h c
40bcm bo432 h c
bo502 h
bo503 h c
bo507 h
bo508 h c
bo482 h
b2482 h
b2587 h
b2592 h
u1096 h c
80-ratio u1096 h
99-hvac u1160 h c
bo-rfa u1000 h c
u1255 h
u1096 h
Thank you.
Old Jan 20, 2009 | 04:23 PM
lucky131969's Avatar
lucky131969
codes
10pcm p1518 h c
28-tcs c1236 h
28-tcs c1278 h c
40bcm bo432 h c
bo502 h
bo503 h c
bo507 h
bo508 h c
bo482 h
b2482 h
b2587 h
b2592 h
u1096 h c
80-ratio u1096 h
99-hvac u1160 h c
bo-rfa u1000 h c
u1255 h
u1096 h
Thank you.
First thing is first. You need to get a handle on the battery drain problem. You need to perform an audit of the electrical system using a DMM. Do you have access to a DMM and a service manual?
Old Jan 20, 2009 | 04:24 PM
byronhunter's Avatar
byronhunter
Have you read this, good place to start.
http://forums.corvetteforum.com/c5-t...tion-long.html
Lucky is a faster on the keybord than I am, he also gives some good info!
Old Jan 20, 2009 | 04:25 PM
01corvettec5
4th Gear
what does dmm stand?
lucky131969
Digital Multi Meter
Old Jan 20, 2009 | 04:26 PM
01corvettec5
4th Gear
No would I just have to take it to autozone or something?
Old Jan 20, 2009 | 04:46 PM
chaase's Avatar
chaase
St. Jude Donor '12
A weak/dying battery causes lots of "problems" for the C5 electronics. Get the drain resolved first and then see what, if any, problems occur.
Old Jan 20, 2009 | 04:47 PM
lucky131969
Sounds like you need to take it to a qualified mechanic. Autozone may be able to evaluate the charging system, but they do not have the ability(or time) to evaluate a current draw problem that is draining your battery.
Old Jan 20, 2009 | 05:22 PM
01corvettec5
4th Gear
Thank you for the detailed info, really appreciate it.
To Need help with codes please
